 Post subject: fail after heads change WD20EARS-07MVWB0
PostPosted: July 21st, 2020, 16:24
hi, I need help
I have a slade 6 that I have had to change heads.
With the donor ROM and its LDR, I can read the entire SA and the heads all ok.
When i put the original rom and load original ldr then they don't read the heads.
Something simple escapes me, but I don't know what it is.
Thanks in advance.
 Post subject: Re: fail after heads change WD20EARS-07MVWB0
PostPosted: July 21st, 2020, 17:09
adaptives?
PostPosted: July 21st, 2020, 17:19
Yes, they are adaptive, but the ROM version is very different and does not take the 0x47 from the donor. I'm going to have to rebuild it by hand.
Any other idea.
Thanks pepe
PostPosted: July 22nd, 2020, 4:35
I have copied the adaptations of the 0x47 module from the donor to the patient and I have not succeeded. At the moment I have run out of ideas.
PostPosted: July 22nd, 2020, 6:15
The patient has rom 0005007 and the donor 00220000.
PostPosted: July 28th, 2020, 7:36
I have a doubt.
If I can read the SA on this hard drive and the heads are working well, are these heads safe to read the user zone?
Thank you.
PostPosted: July 30th, 2020, 14:22
Can anyone explain why the heads of a wd like this breaks all at the same time?
Can scratches from the decks damage the preamplifier?
PostPosted: July 30th, 2020, 20:40
Sure.
But I think that your problem is elsewhere.
PostPosted: July 31st, 2020, 2:41
Can you give me an opinion on a possible problem? I have placed some heads and I have read 15% of the disk, but the equipment was in bsy and the heads have stopped working. It has happened to me with other albums and I don't know what it can be.
PostPosted: July 31st, 2020, 8:42
mhp666 wrote:
hi, I need help
Thanks in advance.
Which Tool Are You Using For Doing This Work
PostPosted: July 31st, 2020, 9:45
I am using mrtlab.
I have solved the problem with adaptations by adapting module 47, but some heads have broken while reading and this usually happens when I recover discs with scratched plates.
PostPosted: July 31st, 2020, 10:42
mhp666 wrote:
I am using mrtlab.
Well,
Practise On Single Platter Drives ,Learn How To Clean Platters Etc,Bypass Problem Zones
PostPosted: July 31st, 2020, 11:15
mhp666 wrote:
Well,
Thanks for the idea. I think it is a good practice.
I will try to create a method.
Users browsing this forum: No registered users and 47 guests
