 Post subject: how read and write rom with hyperterminal in boot code mode?
PostPosted: September 2nd, 2017, 16:37
Banned User
hi
i want to read and write rom in boot code mode
after entering boot code mode i see several commands
but i dont know which command is for read and write rom
please help me
Mohammad Mazaheri
Email: mazaheri.online@gmail.com
Mobile: +989185005214
 Post subject: Re: how read and write rom with hyperterminal in boot code m
PostPosted: September 2nd, 2017, 17:15
Banned User
Spildit wrote:
For what drive ? Seagate F3 arch ?
hi spildit is good to see you again
yes for 7200.11 and 7200.12
please help me
i know you are genius
Mohammad Mazaheri
PostPosted: September 3rd, 2017, 6:59
Banned User
Spildit wrote:
What about using some sort of firmware tool like SeDiv ?
Can't you Read/Write ROM by normal terminal mode with Y-Modem ?
if you know whick command is for read and write rom please tell me!!!
Mohammad Mazaheri
PostPosted: September 3rd, 2017, 7:57
Banned User
Spildit wrote:
If you want to play by normal mode ....
sysfile 9_32A_0
thanks spildit you are very good friend
i read rom with r32a,9,0 in hyper terminal
but how can i write back rom?
with command w32a,9,0 show error exceed limit?
i live in iran i cannot buy legal sediv or hd doctor or dfl because of sanctions!!!
i using hyperterminal for repairing seagate and wdr 6.0 for repairing wdc
you are genius
i'm sure you finding or finded a way for reading rom with hyperterminal
Mohammad Mazaheri
PostPosted: September 3rd, 2017, 8:40
Banned User
Spildit wrote:
mmzhr wrote:
(...)i live in iran i cannot buy legal sediv or hd doctor or dfl because of sanctions!!! (...)
Can't you use something like paypal or in worst case Bitcoin ?
I'm sure you can send $$$ from Iran to other places. You just have to find some SeDiv re-seller.
SeDiv is software only. License locked to your PC. All transactions are done on-line and you don't need to have hardware shipped to you .... As long as you can send $$$ on-line you should be able to buy SeDiv ...
please send sediv reseller and price in pm thanks
Mohammad Mazaheri
PostPosted: September 3rd, 2017, 12:25
Banned User
Spildit wrote:
Here :
SeDiv FULL (WD Marvell + Hitachi/IBM/HGST+ Seagate ST-10 + Seagate F3 + Toshiba + Samsung + "Format Unit/Regen Translator" on Fujitsu) = $350 USD + re-seller taxes.
List of legal SeDiv Re-Sellers :
http://www.hddoracle.com/viewtopic.php?f=84&t=2104
Regards.
$350 :shock: :shock: :shock:
$350 x 3800 Toman = 1330000 Toman :shock: :shock: :shock:
in year 2011 1 dollar = 1100 toman :D
in year 2017 1 dollar = 3800 toman :shock:
Mohammad Mazaheri
PostPosted: June 20th, 2020, 8:50
i have sniffed this code( one side(not both) serial communication) from costly machine and software,
i don't know what command given to com port,but output log copied ,may it help someone
thanks
Repair_Master
PostPosted: June 20th, 2020, 10:28
thanks
Repair_Master
Write rom_sniffed LOG_ST3500418AS_5VMHN11P_CC49.zip [1014.65 KiB]
Downloaded 671 times
PostPosted: July 30th, 2020, 3:58
F3 Rom Writing script(test and experimental only)
warning:- this script only for test and learn purpose use at your own risk
*first open experimental Script tested successfully
*tested on cc49, may work or may not work with other model.
*only for advance user who have time for wasting.
*it will take 30 minutes for full write,expert can decreese time by changing baud rate ,
*try only on testing pcb without media,
*use bad useless HDD of CCXX firmware series pcb example cc36 cc38 cc48 cc49
#requirement#
Zoc terminal
any sop8 Rom programmer (for testing and reading purpose only)
#writing method#
*go to boot mode with your known method,
*connect with your comport (whatever) at 38400
*use Zoc terminal and Transfer> send text file > choose (Romscript.txt)
*if you Fail then adjust text sending char speed and delay per line
#How to check written Rom#
if the Rom is written perfectely
this PCB will boot
press control Z and (together) (for F3 T>
press control (together) For pcb description and serial model No.
#what to do you Next#
*this is experimental script needs improvement
* write Zoc script which convert Rom into text file or Direct write
Thanks write Reply after test
F3 Rom write Test zoc script.zip [1005.84 KiB]
Downloaded 612 times
Users browsing this forum: Google [Bot], unknown and 51 guests
