 Post subject: Seagate Bacall hard disk failure
PostPosted: August 1st, 2020, 6:07
I have got seagate SV35 series hard disk (ST2000VX000 / CV26)
It is detected with wrong model 00S000G / SN is 000000 and Fw is absent. It is showing correct capacity . Terminal shows "LED: 000000BD FAddr: 00004267 " error.
What should I do to gain access. I have read that this is known defect in this uncommon disk.
Somehow I will have to reach to MC. Any suggestion pls.
 Post subject: Re: Seagate Bacall hard disk failure
PostPosted: August 6th, 2020, 0:56
Hello Terminator2
This is particular defect with some seagate families like Pipeline LP series. Fortunately I have got success with 3-4 cases (I was not able to create head Map though)
Pls. check whether terminal is free or locked , if locked short read channel and establish terminal access. If you could read modules & sysfiles clear SMP flags.
I think this should be enough to improve sector access.
PostPosted: August 6th, 2020, 5:01
Most of the terminal commands are locked, as in all recent sg drives.
The drive has problem with at least one of the overlays, perhaps as a result of fw update?
PostPosted: August 6th, 2020, 10:10
I think what pepe can solve even without checking disk ,I cant with present disk. When it comes seagate pepe is one of the super guru.
I dont know about firmware upgrade but customer brought it in this state. Possible someone to whom it has been given earlier might have attempted.
Fortunately I have been able to gain access to sectors and start imaging. Still headmap is not getting created.
Thanks pepe and Higgsboson
PostPosted: August 6th, 2020, 13:08
good. So the problem is probably with the diag ovl...
PostPosted: August 6th, 2020, 13:58
Well,
The LED BD Error Is a Media Cache Problem Mostly ,I think you removed the set flags in Volume 03 0x093 sysfile to get access or did you regenerate translator
PostPosted: August 6th, 2020, 14:50
a LED BD error can be anything, the cause can be determined by the FAddr parameter.
PostPosted: August 6th, 2020, 23:16
Pepe is great :D , In depth knowledge. :good:
PostPosted: August 6th, 2020, 23:18
Well,
Yes I simply removed MC Flags. There was no need to touch translator.
PostPosted: August 6th, 2020, 23:19
Yes. Thanks a lot pepe. :D
Users browsing this forum: Google [Bot] and 200 guests
