 Post subject: Seagate ST3500641AS 7200.9 Problem
PostPosted: August 9th, 2020, 2:35
Firmware: 3.AGM
Hi
I can read user area but very very slow and this is terminal log
its like pending bug in seagate F3s bug, is there a way to disable and properly get data
Interface task reset
4096k x 32 SDRAM
TONKA4D - 1_Disk    S-76   03-15-07_20:16
Head Mask FFFF - Switch to full int.
              Spin Ready
(P)SATA Reset
AT Er 00 Nwt Er 43 RdWr 0003e.03.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot:  97f29ff7  b8  97f29ff7.3.4ab 0000  005f 0000 0000
CE Log ErrCode=43  LBA=37c2f  Type=4  Remove from Pending 37c2f
AT Er 00 Nwt Er 43 RdWr 0003e.03.0001
Niwot:  9ff79ff7  b8  9ff79ff7.3.4ab 0000  005f 0000 0000
DiskAccess ReadSector EC=43 at 00003e.03.0001
CE Log ErrCode=43  LBA=37c30  Type=5  Add To Pending 37c30
AT Er 00 Nwt Er 43 RdWr 0003e.03.0002
CE Log ErrCode=43  LBA=37c31  Type=4  Remove from Pending 37c31
AT Er 00 Nwt Er 43 RdWr 0003e.03.0004
DiskAccess ReadSector EC=43 at 00003e.03.0004
CE Log ErrCode=43  LBA=37c33  Type=5  Add To Pending 37c33
AT Er 00 Nwt Er 43 RdWr 0003e.03.0007
DiskAccess ReadSector EC=43 at 00003e.03.0007
CE Log ErrCode=43  LBA=37c36  Type=5  Add To Pending 37c36
AT Er 00 Nwt Er 43 RdWr 0003e.03.0009
DiskAccess ReadSector EC=43 at 00003e.03.0009
CE Log ErrCode=43  LBA=37c38  Type=5  Add To Pending 37c38
AT Er 00 Nwt Er 43 RdWr 0003e.03.000b
DiskAccess ReadSector EC=43 at 00003e.03.000b
CE Log ErrCode=43  LBA=37c3a  Type=5  Add To Pending 37c3a
AT Er 00 Nwt Er 47 RdWr 0003e.03.000d
DiskAccess ReadSector EC=43 at 00003e.03.000d
CE Log ErrCode=47  LBA=37c3c  Type=5  Add To Pending 37c3c
AT Er 00 Nwt Er 43 RdWr 0003e.03.000e
DiskAccess ReadSector EC=43 at 00003e.03.000e
CE Log ErrCode=43  LBA=37c3d  Type=5  Add To Pending 37c3d
AT Er 00 Nwt Er 43 RdWr 0003e.03.000f
DiskAccess ReadSector EC=43 at 00003e.03.000f
CE Log ErrCode=43  LBA=37c3e  Type=5  Add To Pending 37c3e
AT Er 00 Nwt Er 43 RdWr 0003e.03.0010
DiskAccess ReadSector EC=43 at 00003e.03.0010
CE Log ErrCode=43  LBA=37c3f  Type=5  Add To Pending 37c3f
AT Er 00 Nwt Er 43 RdWr 0003e.03.0011
CE Log ErrCode=43  LBA=37c40  Type=4  Remove from Pending 37c40
AT Er 00 Nwt Er 43 RdWr 0003e.03.0012
DiskAccess ReadSector EC=43 at 00003e.03.0012
CE Log ErrCode=43  LBA=37c41  Type=5  Add To Pending 37c41
AT Er 00 Nwt Er 43 RdWr 0003e.03.0013
DiskAccess ReadSector EC=43 at 00003e.03.0013
CE Log ErrCode=43  LBA=37c42  Type=5  Add To Pending 37c42
AT Er 00 Nwt Er 43 RdWr 0003e.03.0014
DiskAccess ReadSector EC=43 at 00003e.03.0014
CE Log ErrCode=43  LBA=37c43  Type=5  Add To Pending 37c43
AT Er 00 Nwt Er 43 RdWr 0003e.03.0015
DiskAccess ReadSector EC=43 at 00003e.03.0015
CE Log ErrCode=43  LBA=37c44  Type=5  Add To Pending 37c44
AT Er 00 Nwt Er 43 RdWr 0003e.03.0017
DiskAccess ReadSector EC=43 at 00003e.03.0017
CE Log ErrCode=43  LBA=37c46  Type=5  Add To Pending 37c46
AT Er 00 Nwt Er 43 RdWr 0003e.03.0018
this terminal never ends and keep continue.
 Post subject: Re: Seagate ST3500641AS 7200.9 Problem
PostPosted: August 9th, 2020, 8:48
Hi ,
This is Pending Sector Issue ,The Firmware is doing two things at one time ,What tools you have ,This is a Classing Old Problem and very well handled in pc3k and some other tools
PostPosted: August 9th, 2020, 11:24
Amarbir[CDR-Labs] wrote:
Hi ,
I have MRT Ultra with me, what should I do ?
PostPosted: August 9th, 2020, 12:28
The correct method to clone this drive with pending bug is by uploading a loader.
I'm sorry, MRT is very buggy for handling Seagate F drives, LDR file will not be uploaded properly in MRT utility.
You will need something like pc3k or DFL.
There are other ways to fix CE Log issue via terminal commands, but it is very risky to use those if you need to recover data.
My firmware database:
PostPosted: August 9th, 2020, 12:50
Well,
Even The Old Seagate Doctor Tool Was God in Solving This Issue ,But You Had To Solve And Hotswap Sata Connector ;-)
PostPosted: August 9th, 2020, 13:26
Could you explain how to upload uploader , maybe I'd lucky and solve my issue
PostPosted: August 9th, 2020, 13:27
Well,
could you explain the method ?
PostPosted: August 9th, 2020, 14:52
I would try to upload in ram the APP code and ATA overlay with STcom (not the fake one).
http://www.hddoracle.com/viewtopic.php?f=83&t=1810
You can do it also with Seagate Salvation Data tool if you have it.
The risky way is to give T4E command via terminal, you will lose data if the operation fails due to bad heads or bad service area or if ROM version doesn't match with CERT code.
http://www.hddoracle.com/viewtopic.php?f=83&t=175
You can check in terminal if rom match cert with CTRL+R command
PostPosted: August 10th, 2020, 2:28
okay, anyone have proper loader for this drive? tnx.
PostPosted: August 17th, 2020, 2:40
Hey guys, I couldnt fine proper loader, so decide to do the T4E
but after Ctrl+r terminal show
INVALID Cert Disk Code - ROM Resident Revision Required: AGM6L0
So I guess I cant use this method either?
PostPosted: August 17th, 2020, 14:58
You can search and buy donor drive same as your patient and get uploader code from it.
Users browsing this forum: Majestic-12 [Bot] and 99 guests
