 Post subject: Is it possible to repair these corrupted images ?
PostPosted: August 12th, 2020, 18:18
Hey,
1. I'm noob, but I've spent 20 hours to repair this files
2. I tried almost all what I could find on internet
3. I have few jpeg there - for example, for reference, i have one is corrupted and another is not, want to know if corrupted one possible to repair as well?
4. I cannot figure it out
https://drive.google.com/file/d/1q5wnUB ... rlOnk/view
5. I used theses sites as references:
HEX editor online
https://hex-works.com/eng
HEX to image online
https://codepen.io/abdhass/full/jdRNdj
PNG - File contents analysis
"https://asecuritysite.com/forensics/png?file=%2Flog%2Fbasn0g01.png"
New folder.rar [613.35 KiB]
Downloaded 1114 times
 Post subject: Re: Is it possible to repair these corrupted images ?
PostPosted: August 12th, 2020, 19:10
Contact forum member "Arch Stanton".
https://www.disktuna.com/
PostPosted: August 12th, 2020, 20:45
I just register, not sure how to contact him here\? can you guide a bit? thx
PostPosted: August 12th, 2020, 22:15
I only checked the JPEGs. Unfortunately they don't contain JPEG data. Any idea how they became corrupt? Are they recovered files?
PostPosted: August 13th, 2020, 0:26
crazy story, I copy from 1 HD to 2 HD images..... then I didn't check, and few images didn't transfer.... before that I formatted HD 1 and installed windows on it.... Yes, I recovered 10-15 copies of these images but they all corrupted (strange) - and they have 2-3 versions of HEX.... I was able to get 20% of images somehow playing with HEX.... I don't recall how I did it - I was using online service HEX to Image....
Autopsy 4.15.0 software may help?
PostPosted: August 13th, 2020, 4:24
Doesn't make any sense to me what you're saying. These JPEGs are just binary blob with super high entropy (could be encrypted data) with many invalid JPEG markers throughout the entire files. Combination of that suggests it's not JPEG data.
I don't know Autopsy or what it can do.
Point is, that if you used some file recovery or undelete tool that 'produced' these files then they got it wrong. Could be due to the files being overwritten or that your undelete tool took a wrong turn. If the latter it may be worth trying to recover again using a different method. if you used a file system based recovery tool to recover these files, I'd try to carve instead.
PostPosted: August 13th, 2020, 20:01
I don't know what carve is, what does it mean exactly? what I need to do ? thx
PostPosted: August 14th, 2020, 6:42
Sorry, I should have explained that.
So a normal undeleter or file recovery tool scans for file system structures. Such a structure could contain a filename, file size and points to clusters allocated to a file. A file recovery tool then follows these pointers and this way it can recover the file data. If these pointers are off or the file recovery tool didn't correctly work out the start of the file system and/or cluster size, which renders these pointers useless, it will recover corrupt files.
A carver or raw scanner instead scans for byte sequences that are typical and somewhat unique to be found inside a specific file type. So for example JPEGs start with bytes FF D8 FF. Simplest carver will now assume it found the start of a JPEG file and will save everything from this point up to the end of the file to a new file. PhotoRec is an example of a carver, it is open source and free to use.
Many file recovery tools actually use both methods, so they scan for file system structures as well as file signatures.
PostPosted: August 14th, 2020, 10:42
Interesting, I see, photorec also able to aid with PNG files?
PostPosted: August 17th, 2020, 12:08
wow, thanks - this is one of the fastest and efficient software that I've tried (I've tried 10 most popular ones so far)
1. As I see it also recovers cache images from browsers history?
2. I cannot find my picture by name.... because all the recovered pictures have generic assigned name starting with F****** (*numbers)
any tips?
Users browsing this forum: No registered users and 67 guests
