Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: News for Marvel 88ss9189-bld2
PostPosted: August 27th, 2020, 5:02
I suspect that these two "53CDKI" or "53CDK1" ICs are LDO regulators or load switches. The voltages on C135, C140, C106 and C139 would confirm it one way or the other.
PostPosted: August 28th, 2020, 17:30
Very interesting, do you suggest these LDOs could be the culprits? They could have a heat issue by design...anybody exchanged these and had success? I am not into SFM soldering but I can thread a thread into a running sewing machine's needle if I drink enough coffee... :P
PostPosted: August 28th, 2020, 20:42
When I used to troubleshoot microprocessor based circuits, I started by checking the power supplies, crystal oscillator and reset pin. Checking the supplies shouldn't take very long. You just need a cheap DMM.
PostPosted: September 2nd, 2020, 4:48
There are a couple of things i would check with an oscilloscope...
chip-off is probably not an option due to encryption, unless one can find out how to decrypt...
Users browsing this forum: No registered users and 131 guests
