Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject:
PostPosted: April 25th, 2005, 22:12
POST ERASED
 Post subject:
PostPosted: April 25th, 2005, 22:21
POST ERASED
 Post subject:
PostPosted: April 26th, 2005, 2:22
updated
 Post subject:
PostPosted: April 26th, 2005, 6:19
Sorry
 Post subject: NCR = selfscan ??
PostPosted: April 26th, 2005, 9:15
somehow to late for sugestions :)
DE AD
 Post subject:
PostPosted: April 26th, 2005, 9:55
POST ERASED
 Post subject:
PostPosted: April 27th, 2005, 2:36
fujimax wrote:
Tony wrote:
Please clarify this :
Does a new drive have one copy as CN or NCR and another as AN or NAR.
OR
Do both copies appear in the new drive as NAR and once some errors occur the drive itself changes one copy to NCR ??
Hi, Fujimax,
The 2 copies are identical, and the FW program code changes the FW code report to NCR.
 Post subject:
PostPosted: April 27th, 2005, 11:40
If drive ID's with NCR firmware you are then running from ALTERNATE SA area :o be careful
 Post subject:
PostPosted: April 27th, 2005, 11:50
updated
 Post subject:
PostPosted: May 1st, 2005, 11:29
you can do : rewriter 1fh model from the same hdd.
 Post subject:
PostPosted: May 1st, 2005, 12:45
Nice. :-)
 Post subject:
PostPosted: May 2nd, 2005, 23:27
2 cuke:
I disagree...
The corruption of ANY important module can take the drive into the ALTERNATE mode as "NCR" If you had success with rewriting the module 1F that simply means that the module 1F was corrupt and that caused the drive's "NCR" issue. Once that module was fixed - drive started working.
So, it's not because of 1F module. That can be with any module. I had situations where I had to fix just Glist, Plist and some other modules that "switch" the drive into "NCR".
Just sharing the info...
 Post subject: N40P
PostPosted: May 14th, 2005, 19:48
Hi, anyone know how to (and use what to) save my working 6e040l0 to N40P? Do I have to set the drive to the safe mode? And how do I set it to safe mode?
Users browsing this forum: ccc, Thedatarecoverylab and 114 guests
