 Post subject: Maxotr STM3160215AS No detect
PostPosted: October 28th, 2020, 3:39
Hey guys
I have this OLD drive and and to access to Users data
No strange noise, and this is terminal, any advise ?
Reset
1024k x 16 DRAM
NHAWK - 1_Disk    S-42   03-27-07_13:01
HM SFI
(P)SATA Reset
Failed sys sect. write! Nwt Er 7c RdWr 1349c.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 1349e.00.022b
This is old Seagate F drive not F3.
And I have access F level.
 Post subject: Re: Maxotr STM3160215AS No detect
PostPosted: October 28th, 2020, 4:14
Almost sure it's a head problem.
ACELab partner
PostPosted: October 28th, 2020, 4:53
Why head?
is there any command Like m0,2,2,,,,,22 for this old drives ?
PostPosted: October 28th, 2020, 5:16
that 'm' command is not magic, despite many consider it so. And there's no magic for these either.
Pc3k has a patch for this problem that works on most pre-F3 firmwares but not all.
On the other hand, it can be a sign of weak/contaminated heads as well, as PcLab said.
PostPosted: October 28th, 2020, 7:35
So I have MRT Ultra, Can I use this patch ?
PostPosted: October 28th, 2020, 8:33
I haven't ever used MRT, so i cannot tell if it has such option or how to access it.
Try asking their support or forum.
PostPosted: October 28th, 2020, 10:25
What the name of patch in PC3K? or what is do , so I can simulate that in MRT.
PostPosted: October 28th, 2020, 12:02
it can be initiated from within Data Extractor using a loader, among a couple of other patches.
PostPosted: October 28th, 2020, 12:32
I Get its Loader and have this option in MRT, what would you suggest I use?
PostPosted: October 28th, 2020, 16:24
it won't help just uploading a loader. This dialog does not present anything in addition to ldr loading.
PostPosted: November 2nd, 2020, 2:57
HI
I have access to both tools , PC3k and MRT, and I can tell you that only PC3k have that option in the Seagate U5 utility....No way you can simulate those steps in MRT.....The U5 utility in MRT is too simple and without any DR options to be used.
Rgds
www.datasave.ro
Users browsing this forum: No registered users and 418 guests
