 Post subject: How copy a USB dongle?
PostPosted: November 11th, 2020, 6:13
I'm using Linux and I want to know how can I copy a USB dongle? Some devices need special USB dongle to work and when I plug it to my system then Linux tell me that a new device attached, but nothing mounted!
[18167.789715] usb 2-8: new high-speed USB device number 4 using xhci_hcd
[18167.939101] usb 2-8: New USB device found, idVendor=0c76, idProduct=0005, bcdDevice= 1.00
[18167.939105] usb 2-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[18167.939108] usb 2-8: Product: USB Mass Storage
[18167.939111] usb 2-8: Manufacturer: GENERIC
[18167.940237] usb-storage 2-8:1.0: USB Mass Storage device detected
[18167.940608] scsi host6: usb-storage 2-8:1.0
[18168.954318] scsi 6:0:0:0: Direct-Access     GENERIC  USB Mass Storage 1.00 PQ: 0 ANSI: 2
[18168.954752] sd 6:0:0:0: Attached scsi generic sg3 type 0
[18168.955461] sd 6:0:0:0: [sdc] Attached SCSI removable disk
How can I access to this device?
Thank you.
 Post subject: Re: How copy a USB dongle?
PostPosted: November 11th, 2020, 6:22
0c76 JMTek, LLC.
0001 Mass Storage Controller
0002 Mass Storage Controller
0003 USBdisk
0004 Mass Storage Controller
0005 Transcend Flash disk
0006 Transcend JetFlash
0007 Mass Storage Device
1600 Ion Quick Play LP turntable
1605 SSS Headphone Set
1607 audio controller
5663 Audio Device
could be None
PostPosted: November 11th, 2020, 6:28
einstein9 wrote:
0c76 JMTek, LLC.
0003 USBdisk
5663 Audio Device
could be None
I can't understand?
PostPosted: November 12th, 2020, 3:39
USB devices have "Vendor ID" which is "0c76" which tells you what are you dealing with
It could be real or could be FAKE (as i mentioned before)
Dongle copy is not as easy as you think,,,
and FYI... Linux is not your friend on this... (just saying)
PostPosted: November 12th, 2020, 17:46
Is any special device need?
PostPosted: November 12th, 2020, 22:41
Well,
Brain ....
PostPosted: November 17th, 2020, 2:50
usually there are decent protections in place to prevent copying Dongles.
Better talking to the vendor to support Linux.
Years ago I reversed a few Dongles (for Software) but even that got quite hard.
PostPosted: November 29th, 2020, 14:29
Thank you.
Why do you want to copy a usb dongle? USB dongle is mostly used as a license for different softwares and much more. Which is in terms "not legal to copy".
If you have a good reason to do the job, share both side images of inside pcb of usb dongle.
Users browsing this forum: No registered users and 114 guests
