Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: ST2000DM001 doesn't spin - Need a lot of advices
PostPosted: November 14th, 2020, 8:11
• 3 V port (VCC(A)): 1.5 V to 3.6 V
• 5 V port (VCC(B)): 1.5 V to 5.5 V
control signals are described as 2.7-5.5, which means #OE and DIR pins i guess.
It is confusing though that input levels are given at
Low: 0-0.7(0.8)
High: 1.7- for Vcc=2.3-2.7V on channel A
PostPosted: November 14th, 2020, 9:55
But I had 2 more ROMS (One from my dad and another one I ordered from Aliexpress) and they were read perfectly with no issues.
PostPosted: November 15th, 2020, 12:04
probably a loose contact inside the rom chip itself from the pin to the die. it intermittently cuts off and on giving you the readings you have. Its only a guess though..
PostPosted: November 15th, 2020, 12:34
That could be. There was a "pin/leg" that was reaaaaaaaaaaally weak. When I started with all of this I had no idea how to desolder and I messed up some pins. :?
PostPosted: November 27th, 2020, 20:32
If you want, ship me the original drive and I'll solve it for you for no cost. (Assuming there is no head damage, and just firmware or soldering work),
Users browsing this forum: No registered users and 43 guests
