 Post subject: TOSHIBA MQ COMPATIBILITY FOR HEAD SWAP EXPERIENCE
PostPosted: December 2nd, 2020, 6:03
Sorry guys, I was just wandering if someone of you has ever tested successfully, for TOSHIBA MQ DRIVES, head swap from a donor having the match with the only second part of rev before "/".
Just an example:
patient : xxx yyyy/
donor: xxj yyyy/
Of course with model and manifacturing country both perfectly matching.
Thank you in advance for your answers.
 Post subject: Re: TOSHIBA MQ COMPATIBILITY FOR HEAD SWAP EXPERIENCE
PostPosted: December 2nd, 2020, 6:18
It's hard to find a donor that doesn't work in MQ.
odzyskiwanie danych
PostPosted: December 2nd, 2020, 7:43
DONOR D.REV: AAE AA11/
PATIENT D.REV: AAE AA00/
It didn't work. And replacing donor heads back in donor drive it worked again perfectly.
PostPosted: December 2nd, 2020, 12:11
Guess you were "lucky".
odzyskiwanie danych
PostPosted: December 6th, 2020, 10:39
Yeah! very lucky! :-|
Anyway, after testing 4 headsets, i finally got a perfectly matching donor and drive started like a charm.
100% data recovered, and an happy customer for my work. :wink:
