 Post subject: WD Palmer data recovery
PostPosted: December 30th, 2020, 13:50
hello,
i have this WD Palmer 2.5 drive unable to read many part of disk with slow UNC, the rest of the surface read at full speed. I try with original sata and unlocked pcb ( can read rom and all module ok, also try to apply slow fix with latest WdMarvell 4 ).
trying with retry bad sector and high timeouts some sectors read but at a too slow speed, unfortunately the mft is just in an area not readable at all
any advice whit this family before go to try head swap ?
 Post subject: Re: WD Palmer data recovery
PostPosted: December 30th, 2020, 18:21
i guess most of what you can read is only 00's, is it?
I suspect a weak head over there...
PostPosted: December 31st, 2020, 5:43
yes, all zero except boot sector. need to restore original mod32 before slow fix ?
PostPosted: December 31st, 2020, 6:01
swap head from donor read all surface. thanks
PostPosted: December 31st, 2020, 8:51
so weak heads as i suspected?
Users browsing this forum: Majestic-12 [Bot] and 82 guests
