 Post subject: WD Drive Spins, not seen.
PostPosted: December 29th, 2020, 8:29
Hello, I have a WD50EZRZ drive that died when I plugged in a external usb to the PC. I suspect since it spins up but is not seen by the system that there is a fuse or similar blown on the PCB, that I could perhaps replace. Can someone confirm & if true show me the location of the fuses? thanks in advance -John
 Post subject: Re: WD Drive Spins, not seen.
PostPosted: December 29th, 2020, 15:58
If it spins up then it’s 99.9% nothing to do with the PCB.
Much more likely to be a firmware and/or media issue.
PostPosted: December 29th, 2020, 17:23
Doing some more reading I found the term may be TVS diode? The issue seems to fit, I plugged in a USB device to the PC and the drive in the PC immediately failed.
PostPosted: December 30th, 2020, 10:55
Its NOT a fuse...
PostPosted: December 30th, 2020, 12:57
OK. I guess there is nothing to try, the drive is toast.
thanks
PostPosted: December 31st, 2020, 5:48
Or the USB port is toast...
Try on other PC with known good USB ports.
PostPosted: December 31st, 2020, 13:59
The OP wrote "I plugged in a USB device to the PC and the drive in the PC immediately failed". I take it to mean that the internal drive inside the PC stopped working after a different external drive was plugged into a USB port. That makes no sense to me.
PostPosted: December 31st, 2020, 20:29
Maybe OP meant the external drive that was plugged into the PC?
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
PostPosted: January 4th, 2021, 14:37
I plugged an new external drive (to back up the PC). The PC made a click, & shutdown.
The PC would then not boot due to an fstab error. I removed the offending line (disc) and the PC booted. I then took the drive out and placed in a USB enclosure and plugged it into the now running system, whereby it will spin, but not be recognized by the PC (there was 2 drives- the OS on a ssd and a data disc- which is the one that failed). I understand it may be toast, but it would be fun and nice to try to recover data if someone has a idea or link they could toss my way.
thanks
JOhn-
Users browsing this forum: No registered users and 106 guests
