diybit wrote:
We do not see your raw values in your SMART screen, but it seems perfectly good! (maybe take another one with CrystalDiskInfo)
diybit wrote:
The extended test we see in screen is another full erase.
Are you sure you have done the full read extended test?
I had performed a full read extended test previously, before I decided the problem was scary enough to warrant destructive testing.
I'll run it again tonight to be sure the results haven't changed.
diybit wrote:
Perhaps your problem is from the source/destination drive if no error was found, or perhaps not related to hard drives.
The problems occurred when deleting or moving within the same drive so no other drive was involved.
diybit wrote:
What was the problem reported by CHKDSK?
Chkdsk was executed in scan mode on a volume snapshot.
Checking file system on D:
The type of the file system is NTFS.
Volume label is Slow Storage.
Stage 1: Examining basic file system structure ...
956928 file records processed. File verification completed.
Phase duration (File record verification): 18.43 seconds.
14335 large file records processed. Phase duration (Orphan file record recovery): 0.00 milliseconds.
0 bad file records processed. Phase duration (Bad file record checking): 0.43 milliseconds.
Stage 2: Examining file name linkage ...
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RXGAHKF.mkv <0x38,0x1ec>"
... queued for offline repair.
Found corrupt basic file structure for "\Downloads\Shows\True Detective\True Detective S01E01 - The Long Bright Dark - Ehhhh.mkv <0x10,0xa16>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S01E09.HDTV.x264-KILLERS[eztv].mkv <0x70,0x44d6>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RQGNL9L.mkv <0xd,0x7845>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R50US09.mkv <0x4c,0x7a06>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1\9-1-1.s03e08.web.x264-tbs[eztv].mkv <0x15,0x993d>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RMJ63P8.mkv <0x3a,0x10591>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1\9-1-1.S03E09.720p.WEB.H264-METCON[eztv].mkv <0x15,0x115b4>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RY6O02U.mkv <0x1b,0x16d91>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RWLOP3I.mkv <0x30,0x17259>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RH1QE6K.mkv <0x16,0x1cd0f>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R5U6TPP.mkv <0x7d,0x1ec2b>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R637LRG.mkv <0x7,0x1fd98>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RM0SNIR.mkv <0x14,0x20e2d>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RGDL0NT.mkv <0x14,0x20e31>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RXR699K.mkv <0x49,0x20f4c>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RP4RTTL.mkv <0x38,0x210b7>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R3PY2GG.mkv <0x14,0x211be>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R03XWUL.mkv <0x2f,0x21253>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R46P7GT.mkv <0x30,0x2126b>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RLRT7LB.mkv <0x65,0x21737>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RQLG4LH.mkv <0x1e,0x2224f>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R6C2D5O.mkv <0x54,0x24180>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RAQ4X9S.mkv <0x4b,0x27fef>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1\9-1-1.s03e05.web.x264-tbs[eztv].mkv <0x3d,0x28285>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R8VYUAQ.mkv <0x54,0x2b2ed>"
Found corrupt basic file structure for "\Downloads\Movies\Sing.2016.720p.WEB-DL.850MB.MkvCage.mkv <0x5,0x2f456>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1\9-1-1.s02e17.web.x264-tbs[eztv].mkv <0x17,0x2f91f>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RG3KRKP.mkv <0x1b,0x30f76>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RXFNRV9.mkv <0x1f,0x313b5>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S02E14.HDTV.x264-SVA[rarbg]\A.Million.Little.Things.S02E14.HDTV.x264-SVA.mkv <0x56,0x32705>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RPC5ECD.mkv <0x43,0x32de4>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R0IBIRF.mkv <0x24,0x33c99>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RT9HHD8.mkv <0x1c,0x35a62>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RXUNPJX.mkv <0x1f,0x35c2e>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RWML790.mkv <0x45,0x36785>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RGYHSYG.mkv <0xf,0x37174>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RQAITZS.mkv <0x10,0x3717c>"
Found corrupt basic file structure for "\Downloads\Movies\The Secret Life Of Pets 2 (2019) [BluRay] [720p] [YTS.LT]\The.Secret.Life.Of.Pets.2.2019.720p.BluRay.x264-[YTS.LT].mp4 <0x6,0x37437>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R68YSSS.mkv <0x12,0x37ba8>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S01E11.HDTV.x264-SVA[eztv].mkv <0x1f,0x37f18>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\a.million.little.things.s01e16.web.h264-tbs[eztv].mkv <0x30,0x37f27>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S01E05.WEB.H264-MEMENTO[eztv].mkv <0x2d,0x37f2d>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S01E10.HDTV.x264-KILLERS[eztv].mkv <0x31,0x380fa>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\a.million.little.things.s01e17.web.h264-tbs[eztv].mkv <0x62,0x3857a>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R12QX5Z.mkv <0x1d,0x3895e>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S02E16.HDTV.x264-SVA[rarbg]\A.Million.Little.Things.S02E16.HDTV.x264-SVA.mkv <0x29,0x3969c>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RBJXFCV.mkv <0x38,0x3a097>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RGERXLD.mkv <0x7d,0x3b54b>"
Found corrupt basic file structure for "\Downloads\Shows\The Kominsky Method\The.Kominsky.Method.S01E03.REPACK.WEB.x264-PHOENiX.mkv <0x12,0x3c6f8>"
Found corrupt basic file structure for "\Downloads\Shows\The New Pope\The.New.Pope.S01E04.HDTV.x264-PHOENiX.mkv <0xe,0x3c98c>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S02E13.WEB.H264-XLF[rarbg]\a.million.little.things.s02e13.web.h264-xlf.mkv <0x10,0x3c9df>"
Found corrupt basic file structure for "\Downloads\Comedy\Bill.Burr.Paper.Tiger.2019.HDRip.XviD-AVID.avi <0xe,0x3cb48>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RSPKG0U.mkv <0x12,0x3cbb6>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E05.mp4 <0xf,0x3cbbc>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E02.mp4 <0xf,0x3cbc3>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E04.mp4 <0xf,0x3cbc4>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E08.mp4 <0x12,0x3cbc7>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E06.mp4 <0x15,0x3cc7b>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1 Lone Star\9-1-1.Lone.Star.S01E01.480p.x264-mSD[eztv].mkv <0x27,0x3cd59>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E03.mp4 <0x2c,0x3cebd>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R72K9LV.mkv <0x13,0x3cecc>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RRU1TDP.avi <0xa,0x3ced0>"
Found corrupt basic file structure for "\Downloads\Shows\The Kominsky Method\The.Kominsky.Method.S01E01.WEB.x264-PHOENiX.mkv <0x1a,0x3d48c>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E07.mp4 <0xb,0x3d627>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1 Lone Star\9-1-1.lone.star.s01e07.web.x264-xlf[ettv].mkv <0x16,0x3d69f>"
Found corrupt basic file structure for "\Downloads\Shows\Das Boot\Das Boot (2018) S01E01.mp4 <0xa,0x3d836>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RJGGDEO.mkv <0xd,0x3d83b>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RX53RBH.mkv <0x40,0x3e69c>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S02E12.HDTV.x264-SVA[rarbg]\A.Million.Little.Things.S02E12.HDTV.x264-SVA.mkv <0x13,0x405a0>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RTWW8M1.mkv <0x31,0x42b4c>"
Found corrupt basic file structure for "\Downloads\Shows\The Kominsky Method\The.Kominsky.Method.S01E06.WEB.x264-PHOENiX.mkv <0x2c,0x43331>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1 Lone Star\9-1-1.lone.star.s01e08.web.x264-xlf[eztv].mkv <0x12,0x45f7e>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RTNVCAG.mkv <0x32,0x493dd>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RFU738G.mkv <0x16,0x49eb7>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RHFJ7FK.mkv <0x1b,0x4b0e1>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RRR71P6.mkv <0x2c,0x4b5ec>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RV0SY42.mkv <0x16,0x4c245>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S02E17.HDTV.x264-SVA[rarbg]\A.Million.Little.Things.S02E17.HDTV.x264-SVA.mkv <0x55,0x4c39a>"
Found corrupt basic file structure for "\Melanie\Shows\9-1-1\9-1-1.s03e10.web.x264-tbs[eztv].mkv <0xb,0x4c5ed>"
Found corrupt basic file structure for "\Downloads\Shows\The Witcher\The.Witcher.S01E05.720p.NF.WEBRip.x264-GalaxyTV.mkv <0x17,0x50f36>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RNVN9BU.mkv <0x5b,0x517f5>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RG6XYOK.mkv <0x16,0x52405>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$R369EGR.mkv <0x1b,0x5312f>"
Found corrupt basic file structure for "\Melanie\Shows\A Million Little Things\A.Million.Little.Things.S02E15.HDTV.x264-SVA[rarbg]\A.Million.Little.Things.S02E15.HDTV.x264-SVA.mkv <0x10,0x54173>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RTKK84U.mkv <0x15,0x5ccf9>"
Found corrupt basic file structure for "\$RECYCLE.BIN\S-1-5-21-2397356005-2995597529-2747515548-1001\$RAAWRFX.mkv <0xa,0x5d7a2>"
diybit wrote:
Was your drive connected through SATA?
Yep
