 Post subject: Interpreting S.M.A.R.T. UDMA CRC errors
PostPosted: February 13th, 2021, 18:44
Do S.M.A.R.T. UDMA CRC errors imply that something is wrong with the drive itself and therefore it should be replaced?
 Post subject: Re: Interpreting S.M.A.R.T. UDMA CRC errors
PostPosted: February 13th, 2021, 22:30
AFAIK it indicates data is corrupted between the drive and port, so could be a cable not properly connected or bad cable.
PostPosted: February 14th, 2021, 0:12
This doesn't really answer the question, which was: can it be the drive itself?
PostPosted: February 14th, 2021, 7:18
I think there was a motherboard that had a patch to fix a proble like this. Maybe a Gigabyte..cant remember. also some external UCB drives that have a JMicron controller could corrupt data.
A good way to find out is to note the error counts / SMART data and then put the drive into a different PC with a known good cable, and see if it still has the same behaviour. Until you test something, everything is speculation
PostPosted: February 14th, 2021, 9:19
OK smartass.
PostPosted: February 15th, 2021, 0:32
I think I should clarify that I am not trying to fix any specific problem with cables etc. I just received a hard drive whose S.M.A.R.T. data show CRC errors, and I am trying to figure out if I should return it.
PostPosted: February 15th, 2021, 0:44
Arch Stanton wrote:
OK smartass.
Is this considered to be acceptable language in Netherlands?
PostPosted: February 15th, 2021, 6:38
Online
OK then.
Maybe.
PostPosted: February 15th, 2021, 6:59
As previous answers indicated it may very well not be the drive.
PostPosted: February 15th, 2021, 7:02
hddnotguru wrote:
Arch Stanton wrote:
OK smartass.
It depends I guess, on context/circumstances/audience etc..
PostPosted: February 15th, 2021, 13:45
UDMA crc errors can also increase if HDA contacts on pcb are oxidized. Check those contacts, if you see they are dirty clean them by using a soft pencil eraser.
Also, it is possible to get crc errors if you motherboard sata controller is unstable, which may happen due faulty motherboard, power supply damage or due to overclock.
My firmware database:
PostPosted: February 19th, 2021, 16:19
As much as I appreciate people spending time making suggestions on how to eliminate CRC errors, that was not the question. I have not had any CRC errors on my equipment. I received a hard drive whose S.M.A.R.T. data show that it had UDMA CRC errors in the past. The question is limited to only one issue: is it possible that the drive itself is a problem, as opposed to its pins, motherboard, or cables?
PostPosted: February 19th, 2021, 18:50
what do you consider 'drive itself'?
PostPosted: February 19th, 2021, 22:23
I would have thought that "UDMA" errors would be related to the SATA interface, not the HDA contacts. If there were a problem at the HDA contacts, the errors would be detected as read errors, not interface errors.
AISI, the question is, where is the CRC generated and calculated? How do these errors differ from those reported by the End-to-End Error attribute?
In any case it would seem to me that, as long as the error is detected, then it must be corrected automatically by retransmitting the data.
PostPosted: February 20th, 2021, 14:35
I've seen many drives with just UDMA CRC Errors on smart but with very unstable behavings, which had HDA contacts oxidated.
After cleaning those, drives got stable and UDMA CRC Errors raw value stopped increasing.
I've also seen many drives with a lot of End-to-End Error without notizing any issues, drives where usually very stable.
End-to-End Error should be more straight dealing with sata interface (as bad data cable and/or issues on motherboard) IMHO.
Users browsing this forum: No registered users and 220 guests
