Forum rules
 Post subject: Samsung HD502IJ serial/terminal connection
PostPosted: December 27th, 2015, 12:27
I'm new on this forum, but I think I'll find the answer here.
My Samsung have CRC errors, but I want reset his SMART.
But I have problem with his pinouts. Can anyone help me with this?
 Post subject: Re: Samsung HD502IJ serial/terminal connection
PostPosted: December 27th, 2015, 15:23
I will read this, thanks.
But port in my Samsung is not:
x x x x
but
X X
X X
so i dont know how connect RX and TX.
Drive have CRC error but since 4 years, their value has not increased and i want to reset SMART.
PostPosted: February 22nd, 2021, 0:30
hi, Spildit...
all the tutorials that I saw, teaches you how to clear the entire smart table...
my case is just a bad contact defect on the HDD PCB, which causes wrong information in the smart table, after I removed the bad contact, the increment in the table stopped happening and now I need to eliminate this number, because it is too big and system is accusing a problem in the HDD...
is it possible to clear just one information in the table and keep the other information intact?
PostPosted: February 23rd, 2021, 19:01
sure it is. Just need to find that value in the SA and modify it.
PostPosted: February 24th, 2021, 10:23
ok! thank you so much...
please, could you tell me which command to adjust only one parameter of the smart table?!
I know that need to use the terminal, through the HD serial port...
I just don't know, the commands that I should use!!
Users browsing this forum: No registered users and 14 guests
