Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Help on an Overvoltage Failure/Repair
PostPosted: March 2nd, 2021, 18:33
You can scrape away some of the area around the test points to expose the copper.
Takes a while to settle the readings.
Bottom pair seem to settle on 92 k ohm
Top pair more difficult to get a repeatable reading - seems to settle on 0.6 M ohm
PostPosted: March 2nd, 2021, 18:42
Sorry for multiple posts. Just realised you asked to test it connected to HDD.
Top pair now rock solid and repeatable at 60 k ohm
Bottom pair now take a while to settle on 106 k ohm
EDIT - of course - diodes in circuits so it changes depending on which way round the probes are!
Bottom pair with red on ground 1.01 k ohm
Top pair 3.8 M Ohm
Maybe I've been staring at a multimeter screen too long and it's late :-)
PostPosted: March 2nd, 2021, 19:00
The preamp is not shorted.
Can you measure the resistance of each of the capacitors near V2? If a capacitor is shorted, then that would be bad news.
PostPosted: March 2nd, 2021, 19:07
Doesn't appear to be any shorted capacitors. (multimeter on continuity and I tested basically all the components I could around V2)
PostPosted: March 2nd, 2021, 19:56
I'm confused. Let me get back to you later.
Normally if one end of an inductor is grounded, this would suggest that it is part of a negative converter, in which case the other end of the inductor would be connected to the cathode (striped end) of a nearby diode. However, the nearest diodes appear to be associated with a different inductor.
PostPosted: March 2nd, 2021, 19:58
Thanks for all the help - it's really appreciated.
PostPosted: March 3rd, 2021, 16:30
Sorry, I don't understand what is going on in that area. It's probably safest to get a replacement PCB from a supplier such as hdd-parts.com and let them transfer the "ROM".
PostPosted: March 3rd, 2021, 16:31
Cool - thanks for the help!
PostPosted: March 3rd, 2021, 16:42
I thought I would take the risk and power it up! Foolhardy I know.
However - drive spun up and is recognised by windows. I'm now transferring the data.
Thank you for helping me out!
PostPosted: March 5th, 2021, 16:31
I think that V2 may be associated with the negative DC-DC converter for the preamp, in which case the diode would be inside the motor controller IC. If so, then this would be consistent with a grounded inductor.
In short, I believe that bridging the fuse (after removing the TVS diode) would be all that would be required.
The PCB in the following thread appears to be similar in this respect:
https://forum.hddguru.com/viewtopic.php?f=1&t=41021
The topmost inductor (is it actually a transformer?) might produce positive and negative supplies for the piezoelectric microactuator, but that's just a wild guess.
Users browsing this forum: Google [Bot] and 237 guests
