 Post subject: SSD Kingstone 240 gb i cant remove the partions
PostPosted: March 17th, 2021, 4:42
Hi
I used many partitions tool to remove the SSD partitions but fails.I cloned from hard disk to SSD after finished still the old partitions there .Pls any idea to remove of fix the SSD ?
 Post subject: Re: SSD Kingstone 240 gb i cant remove the partions
PostPosted: March 17th, 2021, 8:02
It might have set itself to read-only mode to prevent further data loss. I had such case recently. Check smart first, to find out a bit more about its condition. A secure erase might give you better results, however, i think it is not a reliable device anymore...
PostPosted: March 18th, 2021, 6:15
Pls find the attach files
PostPosted: March 18th, 2021, 8:13
it does not look too bad...
:roll:
PostPosted: March 18th, 2021, 8:50
They just don't do what you ask them to or are there any specific responses or (error) messages? What if you use for example HxD to zap the first sector?
PostPosted: April 5th, 2021, 20:50
I would try DISKPART. It is somewhat tedious but might be the only way. There are too many functions to detail here so look it up. I would start with CLEAN assuming there isn't anything on the drive you want.
Users browsing this forum: Google [Bot] and 95 guests
