 Post subject: Toshiba MQ01ABD
PostPosted: March 23rd, 2021, 5:30
hi
i have a Toshiba MQ01ABD that suddenly stopped detecting to windows. it spins no clicking sound and connect to MRT shows HDD information: serial and model...etc.
Selected family:MQ01ABD
Model:TOSHIBA MQ01ABD100H
Load Zones : .........................:OK
Cyl Num : ............................:232110
Head Num : ...........................:4
Vendor : .............................:TOSHIBA
Model : ..............................:MQ01ABD100H
Microcode : ..........................:ALF07M0F
Defects in G-List : ..................1225
CP list:33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
i tried to clear SMART and Glist but still in Data Explorer it fails and cannot open the files or read the data and these errors appears:
19:25:15 Read Failed SourceLBA = 0 DestnLBA = 0
19:25:15 Parse node failed! Node path = MRT ATA0 - TOSHIBA MQ01ABD100H - 931.51 GB
also when i go to copy data and it starts reading he sectors all the sectors are red.
when i try to Backup Rom i get this error:
Saving ROM......
Save to the target file:C:\UserDataFile\Toshiba\MQ01ABD\TOSHIBA MQ01ABD100H-ALF07M0F-13P6C7WLT\Data\ROM\0-7FFFF.bin
Address : ............................:0x0
Length : .............................:0x80000
Error in reading ROM!
any help would be appreciated
 Post subject: Re: Toshiba MQ01ABD
PostPosted: March 23rd, 2021, 5:52
It is a hybrid drive.
Probably problem is with NAND component.
PostPosted: March 23rd, 2021, 7:38
Thank you for your reply, is there anyway to confirm? if the NAND is defective and i replace the motherboard and swap the ROM chip would it fix the problem?
PostPosted: March 23rd, 2021, 10:47
Toshiba SSHD (Hybrid drives)
You have to issue >NVA command in terminal and Restart Drive.
This will disable NAND on the drive.
After that check if you can read the drive.
PostPosted: March 23rd, 2021, 14:09
pls pay attention on Techno off
and then reidetify hdd. and check sechora are readable?
PostPosted: March 23rd, 2021, 20:46
thank you for your reply. tried Techno off but unfortunately it didn't work
PostPosted: March 23rd, 2021, 20:52
Thank you, i don't know how to send commands. i read on data_medics and hddoracle to press entre and it will show > prompt. i connected the terminal port (by USB) but i don't know where to press entre? should i press entre when i get into Toshiba utility?
PostPosted: March 24th, 2021, 2:12
No. The Toshiba utility doesn't have a Terminal tab....You'll have to use another utility which have terminal tab (Seagate for ex.) and correct baud rate set or a separate software in windows.
Rgds
www.datasave.ro
PostPosted: March 24th, 2021, 21:08
Rgds
Thank you, i followed your instructions and it fixed the problem so i imaged the whole drive to another also i tried to connect the faulty Toshiba hdd directly to windows to see if i would work now and it did work and all the files and data are accessible. thanks everyone for helping me out
PostPosted: June 9th, 2022, 6:25
Josh256 wrote:
Rgds
I have the same problem with Toshiba MQ01ABD.
Please tell, what tool did you use. I can't find a terminal tab in SeaTools for DOS 1.12
PostPosted: June 11th, 2022, 5:31
Is your drive a hybrid model, too? If it is not, then the problem is different.
PostPosted: June 11th, 2022, 7:50
Yes, I have a hybrid model.
I've bougth a usb->com convertor and connected to the HDD with putty terminal.
NVA command solved my problem.
Thanks everyone for the tips :)
Users browsing this forum: No registered users and 106 guests
