 Post subject: ATA Locked ST1000LM024 (Samsung)
PostPosted: April 26th, 2021, 14:05
Hi, all! Been a lurker for a bit now but I seem to have a hit a brick wall here.
I have MHDD loaded up but don't know where to proceed with unlocking this drive. I had put a password years ago and stupidly did not type it down or store it in my "natural memory file", my brain :lol:
Anyway, if anyone could guide me through this, I'd really appreciate it.
I also have TeamViewer up and running. I'd be willing to pay what little money I can offer. I don't need data recovery, I just want to put this drive into my Xbox 360 whose HDD has finally bit the dust!
Thank you!
 Post subject: Re: ATA Locked ST1000LM024 (Samsung)
PostPosted: April 27th, 2021, 4:30
in that case you could just use secure erase, which clears the pw and wipes the data, leaving you with a usable drive...
PostPosted: April 27th, 2021, 8:07
Sounds like a plan! I will give that a try and get right back to you.
PostPosted: April 27th, 2021, 9:01
Does MHDD have a SECURE ERASE option? I don't see it.
Security level is ight set to high. None of the master passwords I have tried have worked.
PostPosted: April 27th, 2021, 15:20
So MHDD lead me nowhere. (Well I did too a SMART check, posted below.) So I moved into hdparm.
With hdparm I get that error, which after googling, seemed to be a bug in the Linux kernel of ~4.4, so I downgraded my CD of PartedMagic and the error is now an I/O error whenever I try to unlock the drive or erase. Few photos below:
Image Image
Everything I've read says I should be able to unlock this if security is set to high and not maximum but I keep getting I/O errors.
Any guidance on this? I've been at this for over 2 days now.
Thank you in advance!.
