 Post subject: WD WD1600JS-60MHB5 Loader Needed
PostPosted: April 12th, 2021, 10:02
Hello everyone,
I need a loader for WD1600JS-60MHB5
ROM version............................. : 40.8WE
ROM F/W version......................... : 408WE
Overlay F/W version..................... : 40.8WE
Servo F/W version....................... : 02.8M
If anyone has please share.
Thank you.
 Post subject: Re: WD WD1600JS-60MHB5 Loader Needed
PostPosted: April 12th, 2021, 13:35
Surely.
WD2500JS-60MHB5-10.02E04-WD-WCANKJ491884.zip [3.69 MiB]
Downloaded 539 times
PostPosted: April 27th, 2021, 5:34
Thank you. I just came back to this case. I'll try loader now.
PostPosted: April 27th, 2021, 5:38
Drive had motor chip blow. I swapped PCB with rom transfer.
Drive clicked at power on. I swapped with known good and compatible heads but still clicks.
I tried with this loader and I get:
SA dir reading (ID)..................... : Module reading error: Physical read error C/H/S: -1/1/1 (1) Device Error Detected: "SERVO ERROR CODE BASE SvirCalRRO"
Configuration reading................... : Module ID 02 reading error Device Error Detected: "FM ERR DIR"
PostPosted: April 27th, 2021, 7:26
Probably serious servo corruption occured either due to feedback issue on the pcb or due to overvoltage and the preamp damage.
btw, double check the donor pcb, -5V supply can go mad any time...
PostPosted: April 28th, 2021, 6:56
That, or you have head alignment issue.
PostPosted: April 29th, 2021, 5:32
I moved back pcb and heads to the donor and it works fine. It does not seem to be damaged in any way.
PostPosted: April 29th, 2021, 16:41
He said “alignment” not damaged.
PostPosted: April 29th, 2021, 17:05
Re-check heads compatibility.
