 Post subject: Hard drive password
PostPosted: April 17th, 2021, 19:13
I am new to hddguru and i am a novice when it comes to computers. I have a question and I am not sure if this is where to ask it. I have a Dell optiplex 7020. It has a 256 gb ssd that has windows 10 pro loaded on it. It also has a Western Digital 500 gb hard drive. When I turn on the computer I get the dell logo and then it asks for Hdd-0 password. The guy that gave me the Hdd told me the password and I enter it and the computer boot up to windows. My question is there a way to get rid of the password so the computer boots right away to windows? Any help would be greatly appreciated.
 Post subject: Re: Hard drive password
PostPosted: April 20th, 2021, 4:41
A good place to start would be this page and the linked documentation: https://hddguru.com/software/2005.10.02-MHDD/
Also this thread: https://forum.hddguru.com/viewtopic.php ... 7&start=20
PostPosted: April 21st, 2021, 18:58
I probably did not explain my problem very well. I bought this Dell 7020 with a 256 ssd with windows 10 pro loaded on it. Everything was working fine. I obtained a WD 500 GB hard drive from a friend and installed it. The hard drive has a password (abcdefg). The first time I started the computer after installing the hard drive it asks for a password for HHD-0. I type in abcdefg and the computer boots up to windows like it did before. I just wanted to know if there is a simple way to remove this password so I don't (actually my wife) doesn't have to type in the password. I thought if I knew the password it would be easy to change or remove it. Thanks in advance for any suggestions.
PostPosted: April 26th, 2021, 0:31
Look into your Dell Bios at the Security section. There you'll find a section dedicated to drives security. Disable the password for the hdd given the fact that you know it.
Rgds
www.datasave.ro
PostPosted: April 26th, 2021, 3:59
read documentation at https://www.dell.com/support/home/en-au/product-support/product/optiplex-7020-desktop/overview or enter the service tag number at Dell support to find correct documentation if this is not your exact model.
also this link may help https://www.dell.com/support/kbdoc/en-au/000132226/dell-system-prompts-for-a-hard-drive-hdd-or-bios-password
PostPosted: April 28th, 2021, 15:52
Thanks for all the help. I used the advice from "ccc" and went into the bios security section and selected hdd-0 and it said password was set. I entered the password and pressed enter. Got the reply that the old password was incorrect. Remembered reading that Dell could supply a reset password and when you enter it you need to press control and enter. Dell wanted to charge a service fee to provide the reset password which was way more then the cost of a new drive. So I entered my known password for this hard drive "abcdefg" and pressed control and enter. It accepted the old password and deleted it. Victory. Thanks again for the information.
Users browsing this forum: No registered users and 229 guests
