 Post subject: Question preserve data flash memory in cartridge stored
PostPosted: April 29th, 2021, 17:52
In the photo of the snes cartridge board, what type of flash memory is used? is it possible to preserve and prevent the loss of data retention in this flash? i stored this cartridge
 Post subject: Re: Question preserve data flash memory in cartridge stored
PostPosted: April 30th, 2021, 17:51
http://pdf.eepw.com.cn/m20090910/20a4b53bd8ef102c1c2decca43ac00dd.pdf
http://www.farnell.com/datasheets/40281.pdf
http://www.farnell.com/datasheets/82483.pdf
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/max2_mii5v1_01.pdf
https://ww1.microchip.com/downloads/en/devicedoc/41190c.pdf
PostPosted: April 30th, 2021, 19:24
I still have doubts
PostPosted: May 1st, 2021, 17:39
http://www.advanced-monolithic.com/pdf/ds1117.pdf
PostPosted: May 1st, 2021, 19:10
what years retention datra in memory flash?
PostPosted: May 1st, 2021, 19:18
see page 29
PostPosted: May 1st, 2021, 19:31
pdf contain 8 pages
pdf contain 8 pages information not 29
PostPosted: May 2nd, 2021, 13:59
Did you even look at the links fzabkar provided? If you only have 8 pages you're looking at the wrong pdf, if you don't understand the information say that - we don't know how technical you are.
PostPosted: May 2nd, 2021, 15:01
i read i not see this information
PostPosted: May 2nd, 2021, 16:41
:rtfm: Page 29 - Table 7
PostPosted: May 2nd, 2021, 17:21
... and 45 years for the FRAM (on page 1 of its datasheet).
The flash stores the Nintendo game ROM while the FRAM stores the scores and game progress (?).
PostPosted: May 2nd, 2021, 17:38
not is possible to avoid this data loss to exceed 20 and 45 years? in the memories chip? i not erase and write was constantly written only once the OS firmware
PostPosted: May 5th, 2021, 20:53
??? question above
PostPosted: May 6th, 2021, 5:56
All of us can only rely on what the datasheet says. It does not mean it will forget all bits one day after the 20, 45 or whatever years the DS specifies, it might hold it for a lot longer interval, but there's a chance it gets corrupted. I think the environment (temerature, various kinds of radiation) definitely has effect on data retention, but i doubt any of us here performed any experiments on the matter.
PostPosted: May 9th, 2021, 6:55
in the board memory chips are flash NOR and FRAM?
PostPosted: May 11th, 2021, 9:45
If you are so worried about technical aspects of DATA storage, why are you rubbing circuit board on carpet? Maybe you need to look up ESD as well.
Not sure what the actual purpose of these questions are, are you planning a time capsule?
Users browsing this forum: No registered users and 17 guests
