 Post subject: re:seagate ST4TB hdd bad firmware or bad disks??
PostPosted: May 14th, 2021, 2:39
I have a Seagate 4TB model number ST4000DM000-1F2168 has so much bad sectors that are unrecoverable according to Puran Disk Fresh software i used on it and would like to know if a i would need a new hdd controller board or replacement hdd disk platters to solve the excessive amounts of unrecoverable bad sectors,bad
delays???
updated: have been able to reformat this hdd(SMART status check back as:OK in Victoria disk utility) but windows disk check utility nor HDD regenerator are able to complete a disk check of bad sectors without glitching out due to "hard disk not ready" error or freezing up!!??!!
If any one knows a Seagate 4TB sata hdd firmware flashing program that works in windows please give me a reply!!
 Post subject: Re: re:seagate ST4TB hdd bad firmware or bad disks??
PostPosted: May 14th, 2021, 3:30
Hard drives don't work like that.
Your drive is failing - probably due to a hardware fault or it could just be a bad drive. Recover the data you need and safely dispose of it before it dies completely and takes your data with it.
Users browsing this forum: Majestic-12 [Bot] and 64 guests
