Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Bluetooth speaker eeprom
PostPosted: May 25th, 2021, 10:18
The complexity comes from trying to do a lot with a small MCU. Plus you would be surprised how many technologies get mashed together in very small cheap devices: CPU's, audio codecs, compression algo's, BT stacks, filesystems etc. A lot of it is very old code, buggy.
I have binwalk running fine on my laptop in a Kali VM(that was in my bag!!) but felt it easier to install on my new PC with twin large monitors, as I would likely be using it for hacking around a lot. (it just occurred to me to just copy that VM, doh!)
geeks are prone to run off on tangents.. I saw a good example: show me something that takes 10 minutes to do and instead I will take 10 days to automate it.
PostPosted: May 25th, 2021, 10:40
True LOL.
I guess this project is the equivalent of your quote lol. It's actually a rather 'stupid' project lol. However i've done a couple of these 'stupid' projects now, and man it is nice when you finally figure out stuff. Great learning as well.
I'm actually doing this for a family member, but ultimately, succesfully tapping into this firmware will make it possible to reuse this old crappy speaker, for a nice little homemade bluetooth speaker, instead of throwing it in the bin.
- Oh and i don't know if i've said this yet, but i've already changed the speaker name successfully, so replacing that terrible chinese lady voice, would be PRICELESS :D
PostPosted: May 26th, 2021, 10:41
The firmware might be based on Anyka's Spotlight10 BaseLine and Media Development Kit which uses ARM Development Suite (ADS) Version 1.2 for AK10 MCUs.
- Quote from some random site i strolled upon. Perhaps it's possible to use the 'ARM Development Suite' to disassemble the firmware?
PostPosted: May 27th, 2021, 15:37
I'm very happy to tell you that the problem has been solved. Another guy on a forum identified the files as 'Bluetooth SBC format'. With the help of sbcdec (Linux) it's possible to decode the audio, along with encoding new audio files. From there the process should be pretty similar to my last speaker project, which means it's just a matter of replacing the audio files. Thanks so much for the help so far! :)
PostPosted: May 28th, 2021, 7:31
Nice!
I was in the process of going through different audio codecs with audacity. I spent a while trying PCM and ADPCM, importing as raw with different bitrates etc & different formats as well just looking for anything that had similar frames or even the same kind of structure, to maybe look down the XOR road.
Strange that with the extensive searching for filetypes commonly used for audio, I never came across that one.
Also, I would have thought it would have to be one of the codecs already supported by the speaker.
PostPosted: May 28th, 2021, 7:58
Bugger! I had looked at this page and totally missed the significance:
https://habr.com/en/post/456182/
If I had spent more time, I would have found this at the bottom:
Bonus: SBC reference encoder, A2DP bitstream information and test files. This file was previously posted on Bluetooth website publicly, but now it is available only to those who have joined Bluetooth SIG.
sbc_test_01.sbc
frame size 0x42
9C F2 12 9A 00 00 7B DD DE F7 77 BD DD EF 77 7B DD DE F7 77 BD DD EF 77 7B DD DE F7 77 BD DD EF 77 7B DD DE F7 77 BD DD EF 77
9C F2 12 17 31 00 7E F6 DF BD B7 EF 6D FB DB 7E F6 DF BD B7 EF 6D FB DB 78 E6 DD C5 34 87 75 02 E3 79 35 99 F6 5A E5 47 61 A3
9C F2 12 3C 41 00 BE 83 2D AA 18 54 61 E2 54 86 68 E7 AD 9B 39 96 A5 18 72 98 9F 95 C8 38 6E 29 5C AB 85 30 EE 0D FA 4B 7E 0C
9C F2 12 EC 41 11 C0 6D 2E 3C 3B EE EE EB BB B6 EC E8 22 C8 42 F2 84 33 AA F0 F1 4B BE B0 73 83 C3 F1 6C B5 2B 59 6E D2 9A B2
9C F2 12 F1 41 10 C8 B0 EF AB CC D4 BA 44 B4 70 F2 58 13 65 CF 29 AB BB 82 F5 B3 3A 0D 2F 15 EB A3 43 36 D2 DC 66 07 09 4C 33
9C F2 12 50 62 10 6A 2A 17 8F 16 CB 15 CC D1 75 4C 9E 4B 17 6B B5 C6 89 6C C8 56 91 24 C2 B9 53 70 4B 9B 55 93 54 8A 44 B8 CE
9C F2 12 99 61 11 43 27 16 49 B5 DC 91 EA D2 9D 26 A7 0E 37 BB AD 3F 2C 47 A9 0E CE 14 94 49 9E E3 4A E6 8D F5 A3 4A B0 CE D4
9C F2 12 54 61 01 48 43 5A 53 49 7B 8E 83 23 7D 83 19 B3 46 AF 4D C6 90 79 CA 97 EB 43 7D 08 C8 B2 36 CB 0C 8A 44 FC AE 41 41
9C F2 12 2D 71 11 A5 56 A5 70 C7 32 4D B4 D4 74 36 E0 8D C9 9D 66 1E A3 7F D7 5F 25 C6 6B 71 B1 51 84 25 29 68 4C C3 96 D0 C3
9C F2 12 F9 72 11 8E B3 65 30 DA 5A 16 79 4D 8F BA 64 0E 9A 2A B6 78 C5 9E 25 68 53 1B BA 23 78 D1 DB BB 6A D4 D9 51 C6 91 6D
9C F2 12 57 83 11 A0 16 28 D9 19 70 D2 43 91 93 16 63 B9 98 FD 46 6B 89 AE DE 71 38 4B A5 5A 7A A4 88 91 62 6A 18 40 D2 12 AA
attached is the resource
29l4kd.zip [3.04 MiB]
Downloaded 467 times
PostPosted: May 28th, 2021, 8:43
Thank you very much with the help anyway. Always warming to have strangers help me, and take time out of your lives to help me with my weird projects. :D And thanks for uploading that bonus :D
Users browsing this forum: No registered users and 99 guests
