Post new topic Reply to topic  [ 72 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Hitachi HDD data recovery
PostPosted: June 4th, 2021, 3:29
I got Hitachi Deskstar, Model: HDS721616PLA380.
It is not spinning and completely silent.
I get an identical PCB (identical PCB number and main controller number) but not worked.
I replace the ROM chip in the new PCB with the old one and still not working (not spinning and completely silent).
Any advice?
Thank you.
 Post subject: Re: Hitachi HDD data recovery
PostPosted: June 4th, 2021, 13:41
does it give ID? PUIS by any chance?
PostPosted: June 4th, 2021, 15:21
Where can I find if it gives an ID or not
I did not use any tool, I just connected it to the PC after replacing the ROM chip
could you please explain more?
PostPosted: June 5th, 2021, 9:07
in that case, does it show up during POST?
PostPosted: June 5th, 2021, 9:54
ROM or NV-RAM?
PostPosted: June 5th, 2021, 10:26
ROM or NV-RAM?
yeah, might be neccessary to move both...
PostPosted: June 5th, 2021, 11:11
No it does not
PostPosted: June 5th, 2021, 11:19
Tomset wrote:
ROM or NV-RAM?
What I replaced is SMD Ic with 8 legs and has the number:s93c76
when searched for it on the internet it called EEPROM in all founded sites
I do not know if this unit has an NV-RAM or not, How could it determined ?
PostPosted: June 5th, 2021, 13:09
Most often ROM in the CPU on PLA380
PostPosted: June 5th, 2021, 14:06
i don't have many of these but they have ext sfl, except one. So yes, it might be tricky from here :)
PostPosted: June 6th, 2021, 3:32
Tomset wrote:
ROM or NV-RAM?
I reply before but it did not appears!
It is NV-RAM and it is number:s93c76, When search for it I found it an EEPROM chip
Can MRT read from this disk even if the PC bios did not recognize it?
PostPosted: June 6th, 2021, 11:21
Tomset wrote:
ROM or NV-RAM?
I reply before but did not appears!
It is NV-RAM with the number: s93c76
When Searched for it all result said that it is an EEPROM
PostPosted: June 7th, 2021, 1:39
ROM ID.................................. : AB0A
ROM Code............................. : 0x12ECFD0E
NV-RAM ID............................... : P22IJBCA
Ver USAG............................. : P22IJBCA
NV-RAM
ID...................................... : E2PR
mu code................................. : P22IJBCA
FW Ver Code............................. : 0x12ECFD0E
Everything must match between the donor and the patient.
Sometimes it is enough to change these values in NVRAM. Another time, look for a board with the same ROM version.
PostPosted: June 7th, 2021, 6:54
Thank you very much for this information Tomset
Could you please guide me to how change these values (web site link or any kind of documentation)
PostPosted: June 7th, 2021, 7:08
1) a utility for Hitachi, but they are paid.
2) subtract the programmer, correct the values, put the image here, someone will recalculate the checksum on the complex or in the utility. but you need to know the values from the ROM. and this is not known without the utility.
PostPosted: June 7th, 2021, 10:44
NV-RAM
so what is these values you submit before?
PostPosted: June 7th, 2021, 11:03
this is an example from another disk HDS721616PLA380.
that you need to pay attention to.
MU CODE WF
P2BNEBEA 12ECFD0E P21OABEA
P2DNDBEA 12ECFD0E P23OABEA
P2CNVBEA 12ECFD0E P22OABEA
P2CNTBEБ 12ECFD0E P22OABEA
P22IJBCA 12ECFD0E P22OABCA
P2CNYBEБ 12ECFD0E P2CNYBEA
P2CNEBEA 12ECFD0E P22OABEA
they come across a lot of different ones, it's enough to change the MU-code in NV-RAM for all of them to work
PostPosted: June 7th, 2021, 11:11
I see
And you get these value from the Hitachi utility you mention before?
Please provide it is name or web site link for it.
PostPosted: June 7th, 2021, 11:42
https://www.acelaboratory.com/pc3000.udma.php
http://www.hddgod.com/
PostPosted: June 7th, 2021, 11:46
thank you very much
Users browsing this forum: ccc and 246 guests
