Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: My Wd desktop hard disk is not spinning, no power.
PostPosted: June 8th, 2021, 4:33
Lardman wrote:
This level of corrosion is not normal. That should be a nice clean copper ground pad.
I understand your point. But it may be due to moisture. And this is carbon layer on it. Also it is far away from motor controller IC. When I unscrewed the pcb, there was no single drop of any liquid.
PostPosted: June 9th, 2021, 14:27
Is there anyone who found the solution to repair this??
PostPosted: June 9th, 2021, 14:50
You can try to read the flash ROM. If that succeeds, then that will prove that the MCU is not brain dead.
It's a very long thread, but there are two methods to read the ROM:
http://www.hddoracle.com/viewtopic.php?f=3&t=1983
PostPosted: June 20th, 2021, 2:51
can i use 2060 701590 001 pcb in replace of 2060 771640 003 pcb
PostPosted: June 20th, 2021, 3:17
pvprashant1803,
No,
CPU different.
Users browsing this forum: Majestic-12 [Bot] and 89 guests
