 Post subject: Donor Heads 58 Grenada
PostPosted: June 8th, 2021, 14:36
Hi to all! HDD PATIENTE ST3000DM001
Model number: Match the model number exactly.
Serial number: Match the second and third characters of the serial number.
HEADS map: Match the physical
heads (PH) map exactly. It is OK if the donor has more heads than the original drive, but all heads before that should match.
Part number: Match the 1st half of the part number. If the second half also matches, it is likely to be an even better match.
Is this information correct for this model?
Thanks!
Нет ничего невозможного
 Post subject: Re: Donor Heads 58 Grenada
PostPosted: June 8th, 2021, 16:43
I would match HM, PRE and sometimes first part of PN
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: June 9th, 2021, 7:40
Ok thanks!
PostPosted: June 9th, 2021, 7:41
Thanks!
Sorry,
After changing the heads it is necessary to do another action in the utility??
Users browsing this forum: Google [Bot] and 244 guests
