Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Hitachi HDD data recovery
PostPosted: June 7th, 2021, 16:05
Tomset wrote:
Everything must match between the donor and the patient.
Sometimes it is enough to change these values in NVRAM. Another time, look for a board with the same ROM version.
NV-RAM:
since we get the NV-RAM from the patient PCB to the donor one I think thispart is done
ROM
you mention before it maybe in the main controller IC, Is it a solution if I try to get this IC from the patient PCB to the donor one?
PostPosted: June 8th, 2021, 2:57
If IC are alive and do not kill the ROM, it will help. There is not just soldering, a nickel under the chip.
PostPosted: June 8th, 2021, 15:55
can PC3000 change The ROM information in the Donor PCB?
PostPosted: June 8th, 2021, 16:11
nope.
to my knowledge it is a mask rom, ie, cannot be changed, true ROM.
it may be internal flash memory but then its not known outside of HGST.
This is another job where you are unlikely to win without investing in tools, and training yourself a lot to grab the knowledge.
Your procedure would look like this:
read tha data out of the 93LC76, identify firmware version, purchase a donor with matching firmware and solder/program it with the patient data.
Now if you want to buy a donor with specific fw version, the price of the sellers who guarantee that won't be very attractive to you.
To read out that chip, you have 2 choices: buy a reader (this, again, will cost you some bucks), or build a reader yourself (this is unlikely you can finish in a reasonable amount of time with no clue to electronics).
So what's the point? Why not find somebody in your country who can do it at a similar amount of money, albeit uncomparably faster?
PostPosted: June 9th, 2021, 1:24
I can help you to test the patient PCB, if you have a multimeter and can provide a good photo. It may not help, but you may at least find out why the PCB died.
Is this your PCB?
https://files.hddguru.com/index.php?action=view&filename=Hitachi_VLA_0A29531_01_f.jpg&directory=Hard%20disk%20Pictures/Hitachi/SATA&
PostPosted: June 9th, 2021, 2:29
Need to start work with isolating the switch of heads. Leaving the motor contacts. If the motor starts, then the board has nothing to do with it
PostPosted: June 9th, 2021, 6:28
Yes I agree with you, but till now I do not know any one can do this and keep searching.
Is this your PCB?
Please find attached an images for the patient and the donor PCB.
If you mean diod check I do it before for patient PCb and all existing diods are fine but D4 is missing in the patient PCB from begging.
the PCB is belong for my relative and he ask me to help him to retrieve important data.
I did this test before I disconnect the motor connector and try, The same result (no spinning).
Thank you all
PostPosted: June 9th, 2021, 6:32
and here is an images for the main controller ICs for both patient and donor
PostPosted: June 9th, 2021, 13:32
Measure the voltages at V1, V2, V3, V- and V+ with the PCB off the drive. Also measure the resistance of R5 (near V+).
V+ and V- are the preamp supply voltages.
Measure the resistance between ground and each of V+ and V-. Then install the PCB on the drive and repeat the resistance measurements. This will tell us if the preamp has been shorted.
PostPosted: June 9th, 2021, 16:15
hddr,
you have a new PCB. before rewiring NVRAM, did you install it? was the engine spinning?
PostPosted: June 9th, 2021, 16:22
I really appreciate this info.
I assume that this measurement must be done with the donor PCB because it is now has the NV-RAM and the other not, Correct?
PostPosted: June 9th, 2021, 16:27
You can do the measurements on both PCBs without reinstating the NVRAM.
PostPosted: June 9th, 2021, 16:28
This new PCB was working fine on it's drive but when I make a simple swap to the patient one no the motor did not spin and that why I continue to replace the NV-RAM
PostPosted: June 9th, 2021, 16:29
I suppose Franc intends to help you diagnosing the native pcb, maybe get it back to life, since the ROM is in the MCU, so it would be a trivial solution to use it with its own nvram.
PostPosted: June 9th, 2021, 16:31
Ok I will
PostPosted: June 9th, 2021, 16:34
if so I think the NVRAM must re-installed on the patient PCB
PostPosted: June 9th, 2021, 16:39
I wouldn't do this yet. If the MCU or motor controller is faulty, then there would be no point in transferring the NVRAM.
PostPosted: June 9th, 2021, 16:46
I will do the measurement and get back
PostPosted: June 9th, 2021, 17:54
hddr,
но когда я делаю простую замену пациенту, двигатель не вращается, и поэтому я продолжаю заменять NV-RAM
if with a new board without replacing the NV-RAM, the motor did not rotate. There are only two options: Problems in the hermoblock or the board is not of the same configuration. Replacing NVRAM will not help in any way.
PostPosted: June 9th, 2021, 18:03
there are boards on the PLA380
PCB:
0A29374
0A29375
CPU:
0A29625
0A29615
0A29626
0A29300
they are not compatible.
The general recommendation is to look for a board with the same code on the sticker. But and they may not be compatible.
Users browsing this forum: ccc, Google [Bot] and 224 guests
