 Post subject: WD My Passport Ultra - connection sound, but can't access it
PostPosted: July 9th, 2021, 10:16
WD My Passport Ultra 1TB
Issue:
makes connection sound, but can't access it on a PC.
dmesg log:
I have attached the dmesg log.
errno 110 = ETIMEDOUT 110, Connection timed out
Sound:
I have also attached a .wav file of the sound the drive makes.
Can anyone help?
Is this a PCB fault?
Is this a Head fault?
Is this a Actuator/motor fault?
David
20210709-1139_Recording_21.zip [2.71 MiB]
Downloaded 423 times
dmesg - log.txt [3.6 KiB]
Downloaded 410 times
 Post subject: Re: WD My Passport Ultra - connection sound, but can't acces
PostPosted: July 9th, 2021, 12:38
You need professional help. Try contacting either
Sean @ www.pcimage.co.uk or
Chris @ www.trcdatarecovery.com
Both are very fair and honest and will give you an evaluation of the HDD.
PostPosted: July 9th, 2021, 12:51
Sean @ http://www.pcimage.co.uk or
Chris @ http://www.trcdatarecovery.com
What do you suspect the problem might be?
PostPosted: July 9th, 2021, 12:53
If your drive is spinning up and the connection sounds then its not a PCB issue.
So its either firmware, bad sectors or failed/weak heads.
PostPosted: July 9th, 2021, 14:36
You might be lucky with that one listening to it, if the data has value of around (~300gbp) turn it off and don't play with it any more, probably isn't a DIY job but not as bad as it could be.
Users browsing this forum: No registered users and 294 guests
