Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: Replacing the PCB on a ST1000LM014 SSHD
PostPosted: August 6th, 2021, 6:41
Hello guys,
I need help replacing the board on my SSHD ST1000LM014 with liquid damage.
The plan:
1. Secure Erase of the donor drive with a Seatools USB Stick and the option "Overwrite Full".
2. Transfer of the ROM from the patient to the donor PCB (with a CH341A ROM reader, an 1,8V adapter and an Pogo Pin WSON 6x5 adapter).
3. Swapping the PCBs.
4. Init of the NAND using the diagnostic port with the command /O and I.
5. Restarting the hard drive.
I base my plan on these two posts:
https://forum.hddguru.com/viewtopic.php?f=1&t=39477
https://forum.hddguru.com/viewtopic.php?p=251854
The Hard Drive Informations:
Patient Drive:
ST1000LM014
Date: 15085
Site: WU
P/N: 720278-002
SN: W382FQW1
PN: 1EJ164-021
FW: HPM6
Donor Drive:
ST1000LM014
Date: 14515
Site: WU
P/N: 720278-002
SN: W3823AG9
PN: 1EJ164-021
FW: HPM6
Now I have these questions:
Do you think my plan is realistic or would you do something differently?
Do I have to pay attention to something?
Can I try to read the ROM with a 1,8V adapter or should not use a adapter and try it with 3,3V?
Is "Overwrite Full" the right option for the secure erase or "Erase Track ZERO" or
should I use a other secure erase tool?
It would be very nice if someone could help me. :D :D
 Post subject: Re: Replacing the PCB on a ST1000LM014 SSHD
PostPosted: August 8th, 2021, 8:46
Hello again,
I did a secure erase on the donor drive with hdparm (It was ready after about 3 hours).
After that I transferred the ROM (It worked with a CH341A, a 1,8V apdapter and a pogo pin adapter).
And after that I swapped the PCBs.
The drive is now spinning but the computer does not recognize the SSHD.
The terminal say:
Rst 0x40M
Servo Processor Is Reset.
(P) SATA Reset
Waiting drive spin up
(S) SATA Reset
Everytime I click Ctr + Z comes: Waiting drive spin up.
But if I click on Ctrl + Z immediately after connecting the SSHD, I am in the F3 terminal for a short time.
It looks like this:
Rst 0x40M
(P) SATA Reset
Request spin / disc table recovery
ASCII Diag mode
F3 T>
Set Transfer Mode selected
PIO selected
Ultra DMA selected
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/O+
Input_Command_Error
F3 T>
F3 T>
RECOV Servo Op=0100 Resp=0005
TCC:001F
RECOV Servo Op=0155 Resp=0005O
ABORT!
OpCode = 00000060
SenseCode = 03310000
ReadyStatusFlags = 0002A181
ABORT!
OpCode = 00000060
Unrecoverable Read Verify Error Reported
(S) SATA Reset
Any idea how I can run the command "/O I"?
Or any idea how can I go on?
PostPosted: August 8th, 2021, 9:00
Fesiplatio wrote:
Hello again,
Double check the patient rom contents against the rom now on the donor. When you say liquid damage - how bad is the original board?
PostPosted: August 8th, 2021, 9:51
Lardman wrote:
Fesiplatio wrote:
Hello again,
Hello Lardman,
thanks for you answer.
I saved the ROMs on the computer in .bin files.
The hash of the ROM file now on the donor is the same like the file from the patient ROM.
So I think the ROMs should also be identical.
As I can see it is the orignial board only slightly damaged, but it has a dark through hole.
I heard it was only little liquid.
PS: I post the two ROM files below.
PostPosted: August 8th, 2021, 10:07
The links to the two ROM .bin files:
The current donor ROM: https://drive.google.com/file/d/1TnHfAMFrRiEO-LE21w_AWQa1lkqN0od3/view
The patient ROM: https://drive.google.com/file/d/1k9hztTikhQPUTp3uNQ9VA31UK_EdYqeH/view
PostPosted: August 8th, 2021, 10:28
Both are identical and PC3K doesn't see anything wrong.
FLASH ROM Info
Image size............... : 1048576
QNR Revisions:
Flash ROM image.......... : 0
CAP
Validation Key........... : 0x00000020
Fam ID................... : 0x72 (Kahuna_5400)
Fam Member............... : 0x1
Head count............... : 4
Date..................... : 20 Aug 2014
SN....................... : W382FQW1
PCB SN................... : 0000N5074VNN
PCB PN................... : ÿÿÿÿÿÿÿÿÿÿ
WWN...................... : 5000C5007C447242
MDL1..................... : ST1000LM014-1EJ164-SSHD
MDL2..................... : ST1000LM014
Capacity................. : 1953525168
RAP
Format revision.......... : 0x0004
Contents revision........ : 0x06010300
Number Sys Zones......... : 1
Number User Zones........ : 60
Heads count.............. : 4
FW Implementation Key.... : 0x16
SAP
Addr 0................... : 0x0001D400
Addr 1................... : 0x40002000
Fam ID................... : 0x72, (Kahuna_5400)
Servo FW rev code........ : 0xB639
Max head................. : 3
Seek mode................ : 2000
Flags.................... : 1AC9
Head vendor.............. : alternative
RRO mode................. : 0005
Preamp type.............. : 00D1
Logical head map......... : 00 01 02 03
Phys head maps........... : 00 01 02 03
                          : 00 01 02 03
                          : 00 01 02 03
IAP
ID, code................................ : 0xFFFF
PUIS.................................... : OFF
Active config........................... : FFFFFFFF
NAND ROM cache flag, Kahuna like........ : 12345678
NAND ROM cache flag, Rosewood like...... : FFFFFFFF
CODE info
Bank 0
ProdType................. : KH6T.HPM1
Controller FW Rev........ : 01141206
Customer Release......... : HPM6
Changelist............... : 00650592
Build date / time........ : 14/01/2014 12:06:38
Package Global ID........ : 00503913
Package Builder ID....... :
Build Rev................ :
Package Rev.............. : CU0SAN
Pkg P/N.................. : 100747282
Servo FW................. : B640 / ---- / ---- / ----
Package Version.......... : KH6T6B.HPM1.CU0SAN.HPM6
Pkg CFW Ver.............. : KH6T.HPM1.00650592.00503913
I hate these drives - you may have more than just a board problem. Someone with a higher success rate with these will be able to confirm.
PostPosted: August 8th, 2021, 10:44
Upload the attached rom - see if it gives you terminal access.
patient_patched.zip [676.82 KiB]
Downloaded 2058 times
PostPosted: August 8th, 2021, 10:49
Lardman,
Many thanks for your help.
I don't see how mechanical damage could have occurred because there really was very little fluid and no other problems.
I'll try the patched ROM right away.
PostPosted: August 8th, 2021, 11:32
I tested the patched ROM and now I have access to the terminal after pressing Ctrl + Z. :D :D
I tried to init the NAND with "/O and I" but after reconnecting the SSHD Windows still says "No media".
This is the terminal output:
ASCII Diag mode
F3 T>/O
F3 O>I
ALF Parametric Tables Preserved
Flash was erased and ALF Tables have successfully been initialized
F3 O>
PostPosted: August 8th, 2021, 12:26
Is the drive seen in the bios and is it shown as the correct size.
PostPosted: August 8th, 2021, 12:40
No, I don't see it in the BIOS and Windows shows the drive only with 0 bytes.
PostPosted: August 8th, 2021, 12:43
Fesiplatio,
after initialization NAND, you need to write the native ROM
PostPosted: August 8th, 2021, 12:47
But the drive is ID'd correctly? I thought it would have given the full drive metrics and just blocked UA access. As Tomset say rewrite the original patient ROM back and give it a power cycle.
PostPosted: August 8th, 2021, 13:01
The drive is also not properly identified.
This is a screenshot from the windows explorer (in German).
I'll change the ROM again right now.
PostPosted: August 8th, 2021, 15:28
Lardman and Tomset,
Yes, wow it worked. :D :D
I changed the ROM again to the original patient ROM and after reconnecting the SSHD, I have all data back.
Thank you soooooooooo much.
I've been busy with this hard drive for an extremely long time and now it worked.
You really helped me alot.
Many Thanks. :D :D :mrgreen: :mrgreen: :D :D
PostPosted: August 8th, 2021, 16:04
Good stuff. Now make a back up (just not on another hybrid drive) :lol:
PostPosted: August 9th, 2021, 3:32
Yes definitely :lol: :D
PostPosted: August 10th, 2021, 5:13
Fesiplatio wrote:
Lardman and Tomset,
Well done Lardman, Tomset. Glad it worked out for him.
I can see from another forum the OP has been trying since the start of the year to get help with this and has done a lot of research on getting another drive with the same FW and finding a way to read off the ROM and also researching the terminal commands.
PostPosted: November 27th, 2023, 13:06
Hi, guys.
I have almost exact same case, except of I have another FW (LVD3)
I'm getting "Waiting drive spin up" on Ctrl-Z after swapping the patient's ROM to donor's PCB.
Please help me with a ROM patch :please:
flash_W25Q80BW_ST1000LM014_Donor.zip [674.63 KiB]
Downloaded 1626 times
flash_W25Q80BW_ST1000LM014_Patient.zip [672.02 KiB]
Downloaded 1676 times
PostPosted: November 28th, 2023, 10:55
Only the patient's ROM was successful
Mikippp
flash_W25Q80BW_ST1000LM014_Patient_Patch_1.zip [672.03 KiB]
Downloaded 1332 times
Users browsing this forum: Google [Bot], kotel and 116 guests
