Hi.
I have a MQ04ABF100 drive. Swapped head. I can read all modules. But cannot access to UA.
I have MRT
Selected family:MQ04ABF100
Model:TOSHIBA MQ04ABF100
Load Zones : .........................:OK
Cyl Num : ............................:371428
Head Num : ...........................:2
Vendor : .............................:TOSHIBA
Model : ..............................:MQ04ABF100
Microcode : ..........................:JU0C0J1Y
Defects in G-List : ..................87
CP list:33,34,44,56,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FE,FF
Saving CP module......
Save to folder:E:\UserDataFile\Toshiba\MQ04ABF100\TOSHIBA MQ04ABF100-JU0C0J1Y-592APZ4BT_2100272_bayram\Data\CP\
33 : .................................:OK
34 : .................................:OK
44 : .................................:OK
56 : .................................:OK
98 : .................................:OK
9A : .................................:OK
9C : .................................:OK
A2 : .................................:OK
A5 : .................................:OK
A7 : .................................:OK
A8 : .................................:OK
A9 : .................................:OK
AA : .................................:OK
AD : .................................:OK
AE : .................................:OK
B1 : .................................:OK
B3 : .................................:OK
BB : .................................:OK
BF : .................................:OK
C1 : .................................:OK
C5 : .................................:OK
C6 : .................................:OK
C7 : .................................:OK
C8 : .................................:OK
C9 : .................................:OK
CB : .................................:OK
CD : .................................:OK
D0 : .................................:OK
D1 : .................................:OK
D3 : .................................:OK
D4 : .................................:OK
D6 : .................................:OK
D7 : .................................:OK
D9 : .................................:OK
DA : .................................:OK
DB : .................................:OK
DC : .................................:OK
DD : .................................:OK
EF : .................................:OK
F1 : .................................:OK
F3 : .................................:OK
F4 : .................................:OK
F7 : .................................:OK
F8 : .................................:OK
FA : .................................:OK
FB : .................................:OK
FC : .................................:OK
FE : .................................:OK
FF : .................................:OK
CP Saving module is ok!
Testing head performance...
WARNING! This test only indicates that if the ABA address can be read or written. It can not reflect the performance of heads. The reading or writiing errors may due to the damage of compiler.
Head ABA writing / reading
NN * Head 0
NN * Beg Cyl : End Cyl : SPT
00 * 0 : 10646 : 5967176
01 * 10647 : 21410 : 6032696
02 * 21411 : 32082 : 6032688
03 * 32083 : 42754 : 6032672
04 * 42755 : 53426 : 6032688
05 * 53427 : 64006 : 6032672
06 * 64007 : 74586 : 6032656
07 * 74587 : 85074 : 6032632
08 * 85075 : 95448 : 5967080
09 * 95449 : 105731 : 5967024
10 * 105732 : 116014 : 5966976
11 * 116015 : 125534 : 5573688
12 * 125535 : 135054 : 5573632
13 * 135055 : 144489 : 5573576
14 * 144490 : 153924 : 5573536
15 * 153925 : 163274 : 5573464
16 * 163275 : 172624 : 5573408
17 * 172625 : 181889 : 5573352
18 * 181890 : 191239 : 5573264
19 * 191240 : 200759 : 5573184
20 * 200760 : 210364 : 5573104
21 * 210365 : 220139 : 5573024
22 * 220140 : 229999 : 5572920
23 * 230000 : 240029 : 5572848
24 * 240030 : 250144 : 5572768
25 * 250145 : 260429 : 5572696
26 * 260430 : 270799 : 5572624
27 * 270800 : 280999 : 5572592
28 * 281000 : 291029 : 5572560
29 * 291030 : 300889 : 5572512
30 * 300890 : 310579 : 5572480
31 * 310580 : 320184 : 5572440
32 * 320185 : 329619 : 5572408
33 * 329620 : 338884 : 5572376
34 * 338885 : 347979 : 5572320
35 * 347980 : 356904 : 5572280
36 * 356905 : 365659 : 5572240
37 * 15729684 : 15734408 : 4918680
38 * 15729224 : 15729683 : 67952
39 * 15728640 : 15729223 : 67952
NN * Head 1
00 * 0 : 11101 : 5967352
01 * 11102 : 22325 : 6032840
02 * 22326 : 33641 : 6032784
03 * 33642 : 44957 : 6032736
04 * 44958 : 56365 : 6032688
05 * 56366 : 67773 : 6032640
06 * 67774 : 79181 : 6032592
07 * 79182 : 90681 : 6032544
08 * 90682 : 102056 : 5966952
09 * 102057 : 113431 : 5966904
10 * 113432 : 124806 : 5966888
11 * 124807 : 135346 : 5573600
12 * 135347 : 145886 : 5573576
13 * 145887 : 156426 : 5573536
14 * 156427 : 166966 : 5573488
15 * 166967 : 177421 : 5573432
16 * 177422 : 187876 : 5573408
17 * 187877 : 198331 : 5573352
18 * 198332 : 208786 : 5573296
19 * 208787 : 219241 : 5573232
20 * 219242 : 229611 : 5573176
21 * 229612 : 239981 : 5573120
22 * 239982 : 250351 : 5573064
23 * 250352 : 260721 : 5573008
24 * 260722 : 271006 : 5572952
25 * 271007 : 281291 : 5572896
26 * 281292 : 291576 : 5572840
27 * 291577 : 301861 : 5572760
28 * 301862 : 312146 : 5572680
29 * 312147 : 322431 : 5572608
30 * 322432 : 332716 : 5572544
31 * 332717 : 343086 : 5572480
32 * 343087 : 353456 : 5572408
33 * 353457 : 363826 : 5572336
34 * 363827 : 374196 : 5572264
35 * 374197 : 384566 : 5572192
36 * 384567 : 394936 : 5572128
37 * 15729684 : 15734408 : 4919000
[b]Total number of physical sectors:151117930600
Total number of logical sectors:1953525168[/b]
I faced the same problem before MQ01ABF050 models. Are those models still undiscovered for DR also MRT ?
By the way, I'm not sure if my donor is compatible.
