 Post subject: ST1000lm035 not doing anything
PostPosted: August 22nd, 2021, 5:23
Hello there,
as I had the issue that my HDD stopped working I will try to fix it. I hope this is the right place to get some advice:
HDD Data:
Seagate ST1000LM035; FW: LVM2; Part Number 1RK172-071, SN: ZDE3PXM7, DOM 11AUG2017, PCB: 100809471 REV A
Following situation:
Laptop hasn't been used for about 3 weeks -> HDD not showing in BIOS; external case doesn't work as well
HDD has not been dropped; doesn't make any sound when connected (no spinning, clicking etc)
What I did so far:
Ordered a donor PCB from another ST1000lm035 with matching Information:
Part Number, FW, LC P/N, PCB Number and Rev
Is it necessary to swap the Hdd FW chip in this case?
 Post subject: Re: ST1000lm035 not doing anything
PostPosted: August 22nd, 2021, 5:49
https://www.cheadledatarecovery.co.uk/2018/02/st2000lm007-st1000lm035-worst-hdd-ever/
Put your hand on the drive - can you feel any vibration at all? You can try swapping the PCB's to see if it spins but if failure wasn't connected to a power incident PCB failure is unlikely. If the data has any value to you, pass it off to a DR professional these are not the drives you want to learn on.
PostPosted: August 22nd, 2021, 6:31
Thank you for the reply!
Loosing the data on it is annoying but I have a backup from about half a year ago which is ok.
Can't feel any vibration at all. I've tried to put my ear on it when plugging it - nothing.
Would you recommend to just swap the PLB and check if it's starting at all and eventually solder the original bios chip afterwards?
PostPosted: August 22nd, 2021, 15:55
Yes, but be careful not to damage the chip.
Users browsing this forum: Google [Bot] and 288 guests
