Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Broken PCB
PostPosted: August 24th, 2021, 9:38
northwind wrote:
I'm not at the office, but this drive is an Apollo, and unless my memory proves me wrong, they have unique 4F module so rebuilding the "ROM" is extremely difficult/unlikely.
I've not had one in yet to play with you're normally right :lol: Time under the scope it is then.
PostPosted: August 24th, 2021, 11:48
It is Apollo, but i doubt it is subject to the same issue Firebird/FBlite/Hubblexx has. Even it is, it can be done, the question is what the original issue was with the drive...
PostPosted: August 24th, 2021, 16:23
The HDD is a WD40EFRX.
The issue with the drive was a wrong power cable. Blow the diodes/fuses, and the repair guy decided to desolder the bios chip instead of the diodes.
"No is also an answer"
PostPosted: August 24th, 2021, 16:46
if the fuses are blown preamp is probably gone as well...
needs mha replacement in that case, not DIY.
PostPosted: August 24th, 2021, 17:03
Preamp damage is much less likely with this particular PCB. It's not affected by the old D3/R67 design stupidity.
PostPosted: August 25th, 2021, 7:10
Thx for clarifying, yes, i haven't checked this actual pcb, just suspected the same design flaw all older pcbs had :)
I can help if you can send the drive over, or contact Marc:http://forum.hddguru.com/memberlist.php?mode=viewprofile&u=5963 , he is in Belgium, a bit closer...
(not sure if distance makes a huge difference though)
Users browsing this forum: No registered users and 210 guests
