Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: WDC WD10S21X-24R1BT0-SSHD-8GB
PostPosted: August 29th, 2021, 17:54
unknown wrote:
In any case, @unknown has already stated than an SSD PCB swap does work.
Yes, tested.
Without any modification.
Was the patient's data contaminated by the donor's cache???
The drive back to work with it's data inside like a brand new.
It was in a Lenovo laptop.
PostPosted: September 3rd, 2021, 11:48
pepe wrote:
The drive starts but gets stuck in bsy state if i removed the SSD board. However, attaching it live makes it get ready. pepe
Mine is quite the opposite. It starts without the SSD board. If i attach it live it goes BSY. If SSD board is connected from the beginning drive always BSY.
What is under the 771980 sticker on the main PCB?
Hynix H5PS5162GFR-S6C - 512Mb DDR2 SDRAM
Marvell 88SE9171 - One-Lane PCIe 2.0 to One-Port 6 Gbps SATA I/O Controller
Marvell 88i9441 - Soleil-H SATA SSHD Controller 6Gb/s SATA, Dual ARM On-Chip Processors, Encryption
WD REDFIN A11SP - Motor Combo IC
Winbond 25X40CLVIG - 4M-bit 2.5V Serial Flash Memory with uniform 4KB sectors and Dual SPI
The SSD SATA lines come out of SSD
Than go to the other side of PCB into the connector
Than to the main PCB and into Marvell 88SE9171 chip.
I could not find where the main SATA port lines go even thou i beeped all the components and pads on the pcb.
PostPosted: September 3rd, 2021, 16:41
In addition to the SATA Tx/Rx differential pairs, there appear to be two signals connecting U8 ("3CTCTN") to J7. I don't know how, or if, these extra signals would affect "cheating".
PostPosted: September 3rd, 2021, 23:15
According to this product sheet, SanDisk's iSSD products conform to the uSSD standard:
http://www.altec-cs.eu/downloads/Produkte/Flash_Speicherkarten/SanDisk/sandisk_oem-products_e09.pdf
Product line iSSD:
6 Gb/s SATA interface, uSSD™ form factor standard with compact BGA-design: 8 GB - 128 GB*; up to 160 MB/s** writing, up to 450 MB/s** reading, with nCache™-acceleration technology (SanDisk‘s SLC write cache) and highly efficient power management.
Here are two uSSD products, with pinouts and pin descriptions:
https://www.intelligentmemory.com/fileadmin/pdf-datasheets/IMSBXXXXTY5SM3B-Z.pdf
http://eflash.apacerus.com/spec/3D/SV170-%C2%B5SSD_AP-USSDxxxGCx58-DPTL_Spec_rev1.8.pdf
PostPosted: January 5th, 2022, 7:33
UPDATE
Cheating with HDD connected instead of SSD did not work.
I finally got SSD pcb replacement and it worked like a charm.
PostPosted: January 6th, 2022, 10:18
That's what I was talking about. :)
Good job.
PostPosted: September 9th, 2022, 6:22
MasterT wrote:
UPDATE
I have the similar patient as yours. Drive always on Busy when power up. When you said SSD PCB replacement, Did you swap anything from the patient SSD PCB to the donor SSD PCB? Or you just swap the whole SSD PCB?
I tried swapping;
1. SSD PCB only - busy
2. SSD PCB and SATA PCB with patient ROM (U12) - also busy.
I tried both method and it didnt work as well.
PostPosted: September 10th, 2022, 15:08
Maybe your problem is not SSD related.
Users browsing this forum: Google [Bot] and 128 guests
