 Post subject: WD10JMVW decrypt image
PostPosted: August 31st, 2021, 5:52
Hello.
Is it possible to decrypt (jms538s) the IMAGE of the hard drive taken after changing the electronics of USB -> SATA. The story is this: I changed the electronics, found that the 0 head was damaged. Instinctively, I made copies of the remaining 3 heads. After taking the image, I found HEH :) that the disk is encrypted. I found the head dose and changed it, it turned out that the head no.2 is weak, it reads slowly or reads with errors. I made an image of 0.1 and 3 heads and unfortunately the old set of heads was damaged, I thought I took them out more gently than the donor, maybe the fresh air hurt them :(. I have 50 hdd of these, but this one is unique.
Any ideas? Thank you in advance.
 Post subject: Re: WD10JMVW decrypt image
PostPosted: September 1st, 2021, 3:13
What equipment are you using? Do you have PC3K?
PostPosted: September 1st, 2021, 3:38
@ northwind
There is no need for the 3k here btw,,, it can be done
PostPosted: September 1st, 2021, 3:57
Yes i have pc3k.
PostPosted: September 1st, 2021, 4:55
https://blog.acelaboratory.com/pc-3000- ... image.html
PostPosted: September 1st, 2021, 5:16
Oh no, it's that simple? I thought that only I was a careless man. And it was described on the blog .... Which I should check. I'm sorry for the trouble.
Users browsing this forum: Google [Bot] and 193 guests
