 Post subject: WD10EZEX - Repair Disk Operations - Initializ self test env.
PostPosted: September 1st, 2021, 5:37
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 0
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: A5C0
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 01.1TG
ROM generation : ...............................: 01.1TG
Link table version : ...........................: 12.21
ROM Firmware version : .........................: 0001001T
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x0
heads map : ....................................:
Load SA translator : ...........................: Err
SA Module Dir Loading...
Load SA Module dir : ...........................: Error, suggest to load from the file
Configuration reading : ........................: Err
Start Self Test...
Write ROM : ....................................: Success
Read 0A module : ..............................: Success
The Head map : .................................:
The HeadDcm and MediaDcm : .....................: 0x4A & 0x5A
Start ROM Mini Test...
Read 0A module : ...............................: Success
The effective Head map : .......................:
Test available headmap...
Load LDR : .....................................: OK
================= MiniCal ====================
Self test information...
The current PTM ID : ...........................: 0xB1
The current TestID : ...........................: 0x4E0
The current action code : ......................: 0x10
Cur Duration : .................................: 00: 00: 52
This test progress : ...........................: Finished, Extended Error Code = 0x7064, Error Code not defined
Selected ROM
Selected Universal Firmware package - TREXXLS.
at end it give above error - still could not able to Repair the DRIVe.
MRTLAB Tech can you please help to resolve?
 Post subject: Re: WD10EZEX - Repair Disk Operations - Initializ self test
PostPosted: September 1st, 2021, 15:17
PostPosted: September 2nd, 2021, 3:02
check the video.
https://youtu.be/t1zqydQq_r8
PostPosted: November 11th, 2021, 16:08
Can you upload Rom.bin And PCB number(2060-771945 ?)
Sexy Womans from your town
