 Post subject: Compact Flash Sandisk 16GB - UDMA
PostPosted: September 18th, 2021, 3:02
I got his card, before doing chip-off, I wonder if there is a safe mode option. I've looked around, couldn't find much info.
Has anyone tried troubleshooting those before ?
When connected to PC-3K PATA, BSY stays always on.
Sam
 Post subject: Re: Compact Flash Sandisk 16GB - UDMA
PostPosted: September 18th, 2021, 4:09
Measure the voltage at the inductor above the "BBO" chip.
https://www.ti.com/lit/ds/symlink/tps62040.pdf
PostPosted: September 18th, 2021, 8:44
Anything shorted what's the power consumption - anything getting hot?
PostPosted: September 20th, 2021, 8:53
Thank you guys. Getting 3V and 5 V
PostPosted: September 21st, 2021, 9:54
Looks like only option will be chip off
PostPosted: September 22nd, 2021, 8:00
Hello suricate.ch, how are you?
This CF seems a little old i believe tools like vnr or flash extractor have support for this controller.
If you dont have tools to work with flash devices you can outsource, will be more easy than find a donor CF with the same controller.
Users browsing this forum: No registered users and 152 guests
