 Post subject: I NEED FIRMWARE
PostPosted: September 10th, 2021, 7:55
please
8TB SEAGATE
ST8000NM0045
1RL112-002
NN02
 Post subject: Re: I NEED FIRMWARE
PostPosted: September 11th, 2021, 3:25
PLEASE HELP
PostPosted: September 12th, 2021, 3:04
SALIM wrote:
please
8TB SEAGATE
ST8000NM0045
1RL112-002
NN02
Ideally do Post with Front and Back CLEAR IMAGE of the Drive will make EASY to help you.
PostPosted: September 14th, 2021, 3:14
please now
PostPosted: September 14th, 2021, 5:23
reliableservice wrote:
SALIM wrote:
please
8TB SEAGATE
ST8000NM0045
1RL112-002
NN02
Am wondering how an image will help YOU here? !!! try to explain more
@SALIM
Seagate firmwares are unique for each drive (specially those new 8TB)
posting the terminal log will explain it more ...
PostPosted: September 18th, 2021, 2:01
please
i think i need LDR
PostPosted: September 18th, 2021, 4:01
This could be the result of a failed or improper firmware update.
Can you upload your ROM? It may be possible to revert to a backup copy of the original firmware.
PostPosted: September 18th, 2021, 11:30
to all members
please
ROM-91.rar [335.43 KiB]
Downloaded 937 times
PostPosted: September 18th, 2021, 14:09
RAP and CAP are bad amongst other bits and the serial number in the SAP doesn't match the label you posted (but does match your MRT screenshot). Above my paid grade I'm afraid.
PostPosted: September 18th, 2021, 14:36
That's only half the ROM.
Following up Lardman's observation ...
https://www.seagate.com/au/en/support/warranty-and-replacements/
Your Product -- Exos 7E
Model Number -- ST8000NM0055
SerialNumber -- ZA108ZNX
Your Product -- Enterprise Capacity 3.5 Hard Drives
Model Number -- ST8000NM0045
SerialNumber -- ZA13WEXP
PostPosted: September 18th, 2021, 14:52
Sloppy seconds on a fubar drive do you think?
PostPosted: September 18th, 2021, 15:07
I'm watching a thread in another forum where an ST2000VM003 drive has been relabelled as a FireCuda, and the CAP in the ROM has been hacked so that the drive reports the fake serial number.
PostPosted: September 18th, 2021, 15:44
I'm following Phil's thread - I just don't see that sort of thing here or at least I don't think I do.
Given how close the 2 drives in this case are I wonder if the pcb being used is original or if it's a board swap without a rom swap.
SALIM have you don't anything to the drive/rom yet?
PostPosted: September 18th, 2021, 16:03
deleted
PostPosted: September 18th, 2021, 16:37
Could we see both sides of the PCB?
Could we see the markings on the chips, especially the ROM?
PostPosted: September 18th, 2021, 22:48
ST8000NM0045 is a standard (non-SED) 4Kn model whereas ST8000NM0055 is a standard 512e model:
EXOS Enterprise 7E8 SATA Product Manual:
https://www.seagate.com/www-content/product-content/enterprise-hdd-fam/enterprise-capacity-3-5-hdd/enterprise-capacity-3-5-hdd/en-us/docs/100827319a.pdf
MRT identifies the family for the ST8000NM0055 as MakaraPlus, so I'm guessing that the ST8000NM0045 is the 4Kn version of the same family.
These firmware updates contain LOD files (loaders):
EntCap-MakaraPlus-STD-SATA-4kN-NN04.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-4kN-NN04.zip
EntCap-MakaraPlus-STD-SATA-512E-SN05.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-512E-SN05.zip
EntCap-MakaraPlus-STD-SATA-512E-SN04.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-512E-SN04.zip
EntCap-MakaraPlus-STD-SATA-512E-PN04.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-512E-PN04.zip
PostPosted: September 19th, 2021, 1:20
thanks
for all of you
PostPosted: September 19th, 2021, 16:41
MakaraPlus NN05 4Kn loader attached.
MakaraPlusEntCapSATA-STD-4kN-NN05.7z [998.5 KiB]
Downloaded 824 times
PostPosted: October 1st, 2021, 10:40
SALIM wrote:
please
i think i need LDR
PLEASE HELP
not solved
PostPosted: October 1st, 2021, 16:08
Why does your drive have two different serial numbers from two different models?
Why have you only uploaded half of the ROM?
Is the drive a fake?
The "Overlay ..." messages in your terminal log would suggest that your drive can reach the SA, so the adaptives would seem to be native, or am I misunderstanding something?
