Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: ST500LX012 - Ultra Mobile SSHD - Short on PCB
PostPosted: September 24th, 2021, 16:41
pepe wrote:
I would hazard a guess that only 0.1% of DR shops have a lab supply.
you have very bad oppinion about DR companies, but we knew that :) Numbers are not that bad i think. (I have 3 just to make them nicer :)
I do think he has one, but let's see.
Polyswitch is ok of course, if you have one handy, but you still need to source 3.3V from somewhere...
Btw, i haven't ever seen a PSU that has 3.3V on SATA power connector, which does not mean they do not exist, just they are not frequent. I think there are more Lab supplies in DR companies than such pc PSUs.
The first post in this thread is typical of DR companies. Clearly the OP has no real experience in electronic troubleshooting. If the customer has reported an overvoltage event, then you start with the protection devices and power supplies. I have written detailed tutorials on the subject, and have also provided a quick-and-dirty explanation, yet people still don't get it, even after hundreds of posts. What use is a lab PSU to people who have no basic understanding, other than to impress clients? You and I can locate the power supplies on unfamiliar PCBs in a matter of seconds by visual inspection. It's not that hard, is it?
I would suggest that people spend some time and learn about the subject. They owe it to their customers. Louis Rossman has written a primer on electronic troubleshooting. That would be a good start.
As for PSUs with 3.3V on the SATA cable, I see them all the time in the user forums. People are often reporting that a new drive drive won't spin up. That's because there is 3.3V on the Power Disable pin.
I have to disagree. I've been reading a lot of your post, I was almost sure I could fix that PCB myself as your post have been very helpful and I can fix standard PCB pull-up resistor, diode issue.
That one is different. SSHD with NAND are not common and I never had one before, so instead of doing something that I would regret I prefer asking. I've learned something, next time, I'll look for DC-DC converter.
I use R&D Lab PSU everyday to troubleshoot smartphone.
PostPosted: September 24th, 2021, 19:12
I'm watching a thread in another professional forum where someone, who is equipped with PC3K and Atola forensic tools, is asking where to find the ROM on a WD PCB (U12), and whether this ROM needs to be transferred to the donor. So tools are one thing, but knowing what to do with them is another. Assuming there is no NAND fault, I could troubleshoot and repair your drive with a $5 multimeter, a short length of wire, and a soldering iron. And it's not because I have any special insight, I'm just applying basic principles.
In your case there is no logical flow in your approach. Any chip level technician who has worked on microcontroller based devices understands that there are 3 primary things to check -- the power supplies, oscillator and reset pin. You don't start by examining the tiny capacitors and resistors (BTW, those tiny black components are usually resistors). These days most electronic devices, including smartphones, HDDs, motherboards and TVs, have switchmode step-down DC-DC converters. The 3 landmarks which identify these power supplies are a piece of silicon, an inductor and one or more capacitors. The silicon component sends pulses into the inductor, and the capacitor smooths these pulses to produce a flat DC output. The output voltage appears at the junction of the inductor and capacitor(s). Look for the inductors and you've found the supplies. It's as simple as that.
http://www.hddoracle.com/viewtopic.php?f=59&t=231
PostPosted: September 25th, 2021, 4:35
I'll look for that next time before posting.
PostPosted: September 25th, 2021, 4:36
Injecting 3,3 V didn't help, still BSY and no terminal. I am looking for a donor PCB, yet haven't found one.
PostPosted: September 25th, 2021, 5:31
This? https://docs.google.com/presentation/d/ ... 3_143_1135
PostPosted: September 25th, 2021, 5:34
Just to check, you have removed the inductor and injected on the right hand side pad?
Did you measure the resistance to ground of the line before doing that, what was the value? this will show if the nand itself shorted to ground. Is anything on the pcb or the nand getting hot and what was the draw on the 3.3v you injected?
PostPosted: September 25th, 2021, 5:46
Line to ground = 210 Ohm.
When connected (PCB on HDD), PCB takes 0.045 from PSU.
PostPosted: September 26th, 2021, 1:02
Yes, that's it. It starts off like a kindergarten lesson, but it eventually picks up. It seems to me that Rossman didn't do much formal training on the subject, but picked it up mostly on the job.
When you get past the basics, this excellent site has a comprehensive rundown of electronics concepts, including animations.
http://www.learnabout-electronics.org/index.php
Buck converters are the most common DC-DC converters you'll see in HDDs and SSDs.
Buck Converter Operation:
http://www.learnabout-electronics.org/PSU/psu31.php
PostPosted: September 26th, 2021, 5:35
I'm about out of ideas other than just blindly blaming the nand. I might bridge the 3.3 back to the other pad in case it's needed anywhere else but I doubt it. Needs the experience of a Senior member of Ace support I think, I be wary of just swapping PCB's :(
PostPosted: September 26th, 2021, 15:41
Would it worth using the ROM from an ST500LT032 to test the PCB? If the PCB then spins up the drive, we can be reasonably confident that the problem is with the NAND or ASIC. I'm assuming that both models have the same MCU and motor controller, otherwise this won't be a conclusive test.
PostPosted: September 27th, 2021, 3:35
I've found a cheap donor, I'll get it before end of the week, I'll keep you posted.
PostPosted: October 4th, 2021, 4:23
Drive works with donor. I'll compare voltage later.
PostPosted: October 4th, 2021, 14:30
You might like to measure the voltages on the tiny bypass capacitors surrounding the ASIC chip. To me it's not clear whether this chip needs a Vcore supply, or whether it runs solely off +3.3V.
Users browsing this forum: Google [Bot] and 218 guests
