 Post subject: Safe mode in Kingston sm2280s3
PostPosted: September 29th, 2021, 9:05
Hello.
Does anyone know the location of the points in the Kingston sm2280s3 drive to put the drive in safe mode.
Thank you in advance
 Post subject: Re: Safe mode in Kingston sm2280s3
PostPosted: September 29th, 2021, 11:18
Just a guess, but besides the Phison controller there's a row of small capacitors, the third slot is empty. Not sure.
PostPosted: September 30th, 2021, 7:52
Safe mode:
PostPosted: September 30th, 2021, 11:16
Thank you.
PostPosted: September 30th, 2021, 13:41
Is that a Phison PS3108 controller?
PostPosted: October 2nd, 2021, 7:44
Yes this is ps3108, the solution given by @Agrail does not work. After the pads are short, the SSD turns off.
PostPosted: October 2nd, 2021, 14:11
Are you shorting the pads before powering on the SSD?
I would measure the voltages at all the potential shorting points. One of the pads must connect to a ball on the Phison controller, and one of the voltages must be at Vio levels. I would find the Vio supply by measuring the voltages at each of the inductors (the components with a white spot). You could also determine the Vcore and Vio voltages by measuring the tiny bypass capacitors surrounding the controller.
I have some ideas here, but your SSD may use a different approach.
How to locate "safe mode" shorting points on an SSD:
http://www.hddoracle.com/viewtopic.php?f=106&t=3088
PostPosted: October 4th, 2021, 7:29
I approached the topic in a different way: I bought a working Goodram C50 disk based on the same chipset, I found a safe mode (3.3V to GPIO0), I desoldered the PS3108 chip, GPIO0 is an E1 ball. In my hard drive I located a vias between the sides of the laminate ... and ... @Agrail actually showed safe mode points ... :( and now another question: do I have a damaged controller or what?
PostPosted: October 4th, 2021, 12:56
What are the voltages at the inductors?
PostPosted: October 5th, 2021, 7:19
@fzabkar 1.2V; 1.5V; 1.8V
PostPosted: October 5th, 2021, 13:04
If the resistances on each rail appear normal with the controller installed, the next place I would look at would be the crystal.
Users browsing this forum: Ahmed Saeed, Google [Bot] and 134 guests
