 Post subject: WD 2T heads issue
PostPosted: October 16th, 2021, 14:29
i have a WD 2T 2.5 which only gives HEAD 0 when imaging any help with that please ?
 Post subject: Re: WD 2T heads issue
PostPosted: October 17th, 2021, 9:49
Probably other heads are bad. You might need to replace them.
ACELab partner
PostPosted: October 18th, 2021, 5:58
it gives HEAD 0 on all sectors does it mean the heads are weak ?
PostPosted: October 18th, 2021, 9:16
What do you mean with gives Head 0?
ACELab partner
PostPosted: October 18th, 2021, 13:24
i mean that when i do create head map with MRT it gives only HEAD 0 and when i am imaging the HDD to another it gives HEAD 0 on all sectors and it images very slow not even 1 Mbps
PostPosted: October 18th, 2021, 13:43
What is the drive model?
Charger, Shrek..etc?
PostPosted: October 19th, 2021, 1:46
Charger
PostPosted: October 19th, 2021, 3:04
You are using the unlocked PCB?
PostPosted: October 19th, 2021, 13:34
no i am using the original PCB
PostPosted: October 20th, 2021, 7:15
it is highly probable that you will screw up the whole thing without proper tools and access to the SA (not possible with orig pcb, at least not without unlock server). It can erase T2 or corrupt the SA with donor heads, then bye-bye data.
So i don't recommend continuing like this, especially it is a client's drive.
PostPosted: October 20th, 2021, 14:05
thanks a lot for your reply i did not do anything with the HDD and handed it back to the client
Users browsing this forum: saltwater and 86 guests
