 Post subject: HTS723232A7A364
PostPosted: October 19th, 2021, 15:05
Need full resources for drive in topic.
FW ver: EC2HA60W
Thanks in advance.
 Post subject: Re: HTS723232A7A364
PostPosted: October 20th, 2021, 6:05
Here you go...
edit: wrong version attached...
PostPosted: October 20th, 2021, 6:09
can you post nvram image?
PostPosted: October 20th, 2021, 8:52
Yeah sure, thanks for trying to help.
The drive came spinning up normally no clicking but no ID ( just FW and capacity 0 )
Heads tested on donor drive and working perfectly.
PCB replaced the same.
NV-RAM_0.rar [2.18 KiB]
Downloaded 371 times
PostPosted: October 20th, 2021, 9:41
Here you go...
Hitachi HTS723232A7A364-EC2OA60W-E383456317WBSN hddguru.rar [1.99 MiB]
Downloaded 373 times
PostPosted: October 20th, 2021, 9:42
does the SN match in nvram and label?
PostPosted: October 20th, 2021, 9:44
Yeah.
But module table USAG in RAM looks garbage
USAG.rar [1.42 KiB]
Downloaded 352 times
PostPosted: October 20th, 2021, 10:44
i think that's normal, coz usag has no valid address in the table, it points to 0.
PostPosted: October 20th, 2021, 10:55
pepe wrote:
Here you go...
Thanks a lot.
Unfortunately, can't figure out what's wrong with the drive.
PostPosted: October 20th, 2021, 12:21
are you able to read SA?
PostPosted: October 20th, 2021, 12:25
No SA access.
Platter has no visible scratches on both sides.
PostPosted: October 20th, 2021, 12:54
kickstarted it?
Users browsing this forum: Google [Bot] and 224 guests
