Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST500LM000 PCB Dead
PostPosted: November 13th, 2021, 4:36
What if you initialise the donor's NAND after the patient's ROM is installed? Will the NAND be reinitialised with the patient's adaptives? Hopefully you won't have two dead drives.
I dont undertand how to do
Sexy Womans from your town
PostPosted: November 13th, 2021, 11:22
I have measured voltages.
Recognised something different than donor. Added pic
PostPosted: November 13th, 2021, 13:30
F3 T>/O
F3 O>I
If the PCB then works on the patient, perhaps it would be prudent to initialise the NAND again on the patient HDA???
PostPosted: November 13th, 2021, 17:19
F3 T>/O
F3 O>I
I have made it also. >O I giving error on terminal if try this command with nonworking drive.
Also tried when drive working with foreign ROM. I dont remember well what was the log. But could be normal log as I remember
PostPosted: November 15th, 2021, 12:38
alberttjohn8 wrote:
Does that mean that all the donor's adaptives (CAP, RAP, SAP) are backed up in NAND? Does it also mean that a bad ROM can simply be substituted by any donor ROM?
Tried same version 3 another different Rom.
All of them working. Accessing to drive and data.
Strange discovery.
But I cannot accessed customers data yet.
PostPosted: November 15th, 2021, 19:26
I would not call it a backup, it is the primary working copy there...
PostPosted: November 16th, 2021, 10:29
WOW.
I have tried so many things. Bricked live PCB at may last attemp. PCB gone endless busy.
After than I could adapt donor PCB to patient. Case solved. Thanks for assits.
PostPosted: November 16th, 2021, 13:06
So you're not going to tell us the solution?
PostPosted: November 16th, 2021, 14:04
Patched ROM (Kahuna PCW Patch 1 ) with MRT.
After then followed 0>I prossedure
PostPosted: November 16th, 2021, 14:58
I would try to lost ROM case for this model.
I think I could solve it now
Users browsing this forum: No registered users and 84 guests
