 Post subject: HGST HTS5410 Problem
PostPosted: November 21st, 2021, 13:20
Hi I have this drive and after 20-30 second get ready in MRT but no ID or capacity, any way to get detect on this model? do I need to load loader ?
 Post subject: Re: HGST HTS5410 Problem
PostPosted: November 23rd, 2021, 11:53
Any suggestion guys?
PostPosted: November 23rd, 2021, 13:27
Send a soft reset; exit then re-enter.
PostPosted: November 24th, 2021, 10:55
First try to boot from H1.
PostPosted: November 24th, 2021, 12:43
Could you explain more, if you mean edit NVram, change to what value?
PostPosted: November 24th, 2021, 13:07
unknown is suggesting you start HDD using a single head to see if you have a head failure.
NVRAM needs to be adjusted to start using a single head physical head 1 ("H1") or logical head 0.
When you edit NVRAM will be like 00 01 FF FF; change 01 to 00 and if that doesn't work change 00 to 01.
I am not sure how this is done in MRT; but it's very simple in PC3000.
PostPosted: November 24th, 2021, 19:54
be aware that such change can ruin the SA on the affected surface...
PostPosted: November 27th, 2021, 10:01
Thank you guys.
Users browsing this forum: Google [Bot] and 269 guests
