 Post subject: WD Charger Strange imaging
PostPosted: November 14th, 2021, 15:45
Hi
Working on a charger, imaging goes fine for few seconds, then speed drops to kilobytes and unstable. A power reset gives full speed but for few seconds.
Anyone faced such behaviour?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD Charger Strange imaging
PostPosted: November 18th, 2021, 9:43
I would try with another power supply. Sounds like it starts to fail after getting warm.
PostPosted: November 18th, 2021, 10:00
I would rather put my vote on background activity...
PostPosted: November 18th, 2021, 21:47
Possible as well.
PostPosted: November 21st, 2021, 8:56
Samir wrote:
Possible as well.
Were are you from india ? . Secondly its background activity and that needs to be taken care of
PostPosted: November 22nd, 2021, 0:32
Amarbir[CDR-Labs] wrote:
Samir wrote:
Possible as well.
I'm not from India (not OP), and I've seen oddball stuff like this an in external drive with a bad charger, which is what it sounds like the OP is dealing with. Could also be background activity as you mentioned, but I would try the charger first as it could completely clear up the issue if the root cause.
PostPosted: November 23rd, 2021, 16:10
Thank you.
__________
THANK YOU
SHAHI
PostPosted: November 23rd, 2021, 16:11
Samir wrote:
Possible as well.
Did you face and dealt such on Charger?
__________
THANK YOU
SHAHI
PostPosted: November 23rd, 2021, 16:38
Samir wrote:
Possible as well.
I'm wondering whether @Samir is confusing an AC/DC charger with Charger (a WD family code).
PostPosted: November 23rd, 2021, 17:29
Samir wrote:
Possible as well.
I was not aware that charger was a family code, so yes, that's why I posted my reply. I learned something new and now realize this has nothing to do with a power supply, lol.
PostPosted: November 25th, 2021, 3:46
Samir wrote:
Possible as well.
Well,
Answer is Yes ....
PostPosted: November 27th, 2021, 14:26
Samir wrote:
Possible as well.
Well,
Answer is Yes ....
I figures out the case successfully
Thanks to all
__________
THANK YOU
SHAHI
PostPosted: November 28th, 2021, 9:06
Great,
Please share so that others can also get benefit ,My Charger Case has a ROM Issue
