 Post subject: (NEED A QUOTE) Kingston USB 16GB HVKJ0FC 1610 115T131G-3S-1H
PostPosted: December 9th, 2021, 6:14
I have a dump from this USB that I need data from.
Can someone assist on this? Let me know what you would charge.
I was just about to pull the trigger on Flash Extractor, as they can also do remote work on USBs for an extra 100USD and that way I would also have the software.
Same as below:
 Post subject: Re: (NEED A QUOTE) Kingston USB 16GB HVKJ0FC 1610 115T131G-3
PostPosted: December 9th, 2021, 6:48
What do you mean a dump - Have you read the nand directly and you're just looking for someone to reassemble ?
PostPosted: December 9th, 2021, 6:53
Hi Lardman,
I read the chip and looking for someone to do that, exactly.
Sorry if I havent explained it properly.
Regards,
PS: I have the the Flash Extractor NAND reader
PostPosted: December 9th, 2021, 6:56
http://flash-extractor.com/library/SSS/SSS6131/SSS6131%20H2-E6C__98_3a_98_a3__1x1
Arvika has already posted a solution in the library assuming the controller is the same as the one in the picture you've posted.
PostPosted: December 9th, 2021, 7:09
Yes I know,
I need to buy the Flash Extractor license in order to work with the dump.
PostPosted: December 9th, 2021, 17:38
Anyone? Jesus Christ this forum is always dead
PostPosted: December 10th, 2021, 13:06
There is labs that are comfortable with flash recovery but have enough of their own. I imagine they don't scavenge forums for jobs. And there are people like me who do flash recovery but not yet comfortable enough to do jobs for others. And then there are some that are known to do flash recovery jobs for many other labs. May be easier just to contact those.
PostPosted: December 10th, 2021, 14:09
Thanks for the input Arch
PostPosted: December 10th, 2021, 15:09
Nandoff is relatively close to you. I happen to know he does a lot of cases for other labs.
PostPosted: December 10th, 2021, 18:33
speakerbox, contact me on PM. I will guide you to upload dumps.
PostPosted: December 10th, 2021, 18:42
And Arvika of course ;)
He was the other potential source of help I had in mind but since Mark is closer ..
