 Post subject: ST8000DM004 needed for heads swap
PostPosted: December 12th, 2021, 21:44
hello Guys i really need a donor for a very important work.
customer need to get data from his passed away relative. sadly i cannot find the right donor here in japan :( :( :( :( :(
if someone got with closer serial, etc i would like to buy :D :D :D
thank you
 Post subject: Re: ST8000DM004 needed for heads swap
PostPosted: December 15th, 2021, 12:54
I think there are several other models could be used for parts... no need for such a strict match.
PostPosted: December 15th, 2021, 14:51
thank you
https://hdddonor.in/product/seagate-st8 ... k-drive-3/
PostPosted: December 15th, 2021, 21:03
shubhsinghal thank you ^^
unfortunatelly i already tried 3 donors but this is F3 model! the donor specification must be almost the same! do you have experience with st8000dm004?
please share with us :D :D
PostPosted: December 16th, 2021, 0:49
The link i sent you is a perfect match according to my experience in DR industry. Don't worry go for it.
Still in doubt?? Share the patient drive ROM file and PCB picture so that i can verify the details for you.
Regards,
Shubh
PostPosted: December 16th, 2021, 21:36
shubhsinghal i have a similar donor but still doesnt accept the heads.
this is the pcb of the Patient
PostPosted: December 16th, 2021, 21:44
according to this site F3 drivers matching guide
PostPosted: December 16th, 2021, 21:52
here is one of my DONOR. should be ok but unfortunatelly doesnt work since the year of production is not the same
PostPosted: December 17th, 2021, 4:24
It matches perfectly with your patient drive. Go for it.
PostPosted: December 17th, 2021, 4:27
This is extremely strict and most of it doesn't make sense.
PostPosted: December 17th, 2021, 12:46
I bet i could do it with any off-the-shelf donor...
It's a matter of convincing power :P
PostPosted: December 18th, 2021, 9:41
hello guys. always happy to hear your opinion. it helps me indeed.
i wish i can be positive about my donor lol. i did tried the donor heads and tried to load the LDR but it wont accept the heads lol too stubborn HDD! it make me crazy because the donor heads works fine on their original HDD
its frustrating lol
PostPosted: December 19th, 2021, 21:48
northwind Sir do you have experience with st8000dm004? could you use donor heads with different year of production?
PostPosted: December 22nd, 2021, 7:29
i know it can be difficult to find a head stack that performs well in all respects, so the question is how you can get it work with the donor heads you have.
coz it is possible, otherwise you might search for 'compatible' donors forever.
