Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate ST2000DM001-9YN164 Firmware Update
PostPosted: December 28th, 2021, 21:11
i bricked hdd with lod fw by seatools how i can revive
PostPosted: December 29th, 2021, 16:48
Boot 0x40M
Servo !supported preamp ID 0000
Spin Up
FAIL  Servo Op=0100 Resp=0003
ResponseFrame 02C0 0000 0000 77C0 0008 0000 0000 0000 F100 0000 0000 0000 0000
0000 0000 0000 66C6 FA3B 29C4 CB66 F8BC 192C 1DD9 DFFA 669E 78F3 0000 007F 0000
0000 FFE2 0004 0010
ResponseFrame FB40 0000 0000 7840 0008 0000 0000 0000 F07F 0000 0000 0000 0000
0000 FFE0 0004 0000
ResponseFrame FD80 0000 0000 7840 0008 0000 0000 0000 F07F 0000 0000 0000 0000
0000 FFE0 0004 0000
ResponseFrame FE40 0000 0000 7800 0008 0000 0000 0000 F0C0 0000 0000 0000 0000
0000 FFE1 0004 0000
PostPosted: January 7th, 2022, 14:57
here is wrongly flashed dump attached. Please send fw dump with null plist glist
ST2000DM001-9YN164-500
FW: CC4B
SN:W240VK8W
File comment: wrong fw dump
25Q40BW.zip [368.21 KiB]
Downloaded 1401 times
PostPosted: January 7th, 2022, 15:22
I am wondering about that preamp id message, it should not be 0000.
Is your pcb correctly attached to the HDA?
PostPosted: January 8th, 2022, 17:12
yes correctly attached already bricked during firmware upgrade
because im not used cfs file. im directly unpack lod file from freedos.img and flashed with seatool bootable cd. not used orginal iso have floppy image..
you can preamp reset in my dump by serial https://www.data-medics.com/forum/threa ... post-18605
PostPosted: January 15th, 2022, 15:47
stil waiting for repair fw
PostPosted: January 15th, 2022, 16:47
I modded the rom so that it might load the old code from the other slot, try this. If it doesn't help, the problem is probably physical.
25Q40BW-1.rar [340.19 KiB]
Downloaded 1375 times
PostPosted: January 15th, 2022, 17:19
i will try thanks. what is other slot means ? can i update rom if disk spin ok
PostPosted: January 15th, 2022, 17:48
I expect that the drive has been updated with the wrong LOD. There is one LOD for 4-head configurations, and another for drives with 5 or 6 heads. I think serial numbers starting with "x24" correspond to 5 heads.
http://www.users.on.net/~fzabkar/HDD/GR-CC4H.TXT
These LODs contain ROM segments as well as 4 SA overlays.
PostPosted: January 15th, 2022, 18:21
tested file and still trying start spin. no effect same. already bricked by myself. im sure disk working with a few bad sectors
ok im flashed manully this file. then wrong. i checked 1 hour before flash fw. I thought my disk had 4 heads. my mistake
GRCC4H4H.LOD
how i can flash lod file directly to spi flash.
PostPosted: February 11th, 2024, 18:12
egavastm wrote:
I contacted HP and they wanted me to RMA my computer. I have no clue if they will post an update.
I got a 2nd ST2000DM001 drive and a serial TTL cable hoping to learn if forcing a firmware update is worth the risk. As you can see below the two drives I have are not comparable.
ST2000DM001-9YN164 HP16 Firmware
Grenada Luxor 2.1 RAP22 - GR Hda DH, DETCR, 4K Zest
Product FamilyId: 58, MemberId: 04
HDA SN: Z1Exxxxx, RPM: 7199, Wedges: 188, Heads: 4, OrigHeads: A, Lbas: 00001D273EAC, PreampType: CB 16
PCBA SN: 0000xxxxxxxx, Controller: LUXORL_2_1( 202)(FF-FF-FF-FF), Channel: ITERATIVE, PowerAsic: MCKINLEY DESKTOP LITE Rev 15, BufferBytes: 4000000
Package Version: GR753C.HPD1.BK06B8.HP16 , Package P/N: 100707026, Package Global ID: 00188399,
Package Build Date: 04/26/2012, Package Build Time: 10:25:04, Package CFW Version: GR75.HPD1.00446199.00188399,
Package SFW1 Version: C3A7, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 04261025, CustomerRel: HP16, Changelist: 00446199, ProdType: GR75.HPD1, Date: 04/26/2012, Time: 102504, UserId: 00188399
Servo FW Rev: C3A7
RAP FW Implementation Key: 16, Format Rev: 0002, Contents Rev: 61 02 00 00
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled v. 3.8.00.0000000000001FF7
- LTTC-UDR2 disabled
ST2000DM001-1CH164 CC26 Firmware
GrenadaBP LuxorPlus2 4K, GPF1 MC with new serpent DFW
HDA SN: Z1Fxxxxx, RPM: 7199, Wedges: 188, Heads: 5, OrigHeads: A, Lbas: 00001D273EAC, PreampType: CC 16
Bits/Symbol: C, Symbols/UserSector: BEB, Symbols/SystemSector: 1A5
PCBA SN: 0000xxxxxxxx, Controller: LUXORLPLUS_2_0( 203)(FF-FF-FF-F, Channel: STX_DUNRAVEN, PowerAsic: Unknown Rev 00, BufferBytes: 4000000
Package Version: GPG17C.CCD2.CB0487.CC26 , Package P/N: 100720588, Package Global ID: 00410638,
Package Build Date: 12/13/2012, Package Build Time: 13:56:37, Package CFW Version: GPG1.CCD2.00515436.00410638,
Package SFW1 Version: C7EA, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 12131356, CustomerRel: CC26, Changelist: 00515436, ProdType: GPG1.CCD2, Date: 12/13/2012, Time: 135637, UserId: 00410638
Servo FW Rev: D7EA
TCG IV Version: n/a
Package BPN: 18
RAP FW Implementation Key: 16, Format Rev: 0004, Contents Rev: 71 01 07 00
QNR Container: 1
Features:
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled v. 4.7.01.0000000000000017
- LTTC-UDR2 enabled
- SuperParity disabled
- Humidity Sensor disabled
- Background Reli Activity Critical Event Logging disabled
Hello, since I bought the Seagate 2TB HDD, it has had a clicking sound. I updated the firmware with an ISO, and it crashed. I am sure I did it correctly, but now it doesn't respond at all. There are no important files inside, but I want to refurbish the disk. I have a CH341A programmer that can both program the BIOS and has a TTL port. I have previously repaired an HDD with F3 commands. The HDD preamp seems to be erased; I opened a topic on this forum before, but it wasn't helpful. Since the HDD is not recognized, I cannot use the same disk. What method can I use to recover the data? Same scenario but my both HDDs are retail, not HP?
My dead HDD;
ST2000DM001
9YN164-500
FW-CC4B
PostPosted: February 11th, 2024, 18:58
https://forum.hddguru.com/viewtopic.php?f=1&t=40070
same problem
Users browsing this forum: flymoth and 134 guests
