 Post subject: ST1000LM035-1RK172 Seagate Mobile HDD 1Tb capacity is 0.00Gb
PostPosted: December 30th, 2021, 0:18
I have problem on ST1000LM035-1RK172 Seagate Mobile HDD , capacity is 0.00Gb :
Already posted in MRT Lab Support Forum website with no response.
1. Hdd is ready, unlocked, SA and hdd resources is saved very well.
2. Unless Sys 28 (translator) copy0 is bad (read error), copy1 is good, so I copied, Sys 28 from 1 to 0, copied done with no error
3. Hdd re-initialized .
3. Problem remain same, 0.00Gb, find in attachment
Anybody can help .
Many thanks.
File comment: 0.00Gb
 Post subject: Re: ST1000LM035-1RK172 Seagate Mobile HDD 1Tb capacity is 0.
PostPosted: December 30th, 2021, 6:14
Check if Sys 28 checksum is ok. If not fix it.
PostPosted: January 3rd, 2022, 2:32
How to check or recalculate seagate sys file checksum?
PostPosted: January 4th, 2022, 16:13
Send me sys28. I might be able to help.
PostPosted: February 4th, 2022, 8:41
Hi MasterT,
Sorry for very late to reply.
Here is sys28, it is from Copy1 as I told before sys28 copy0 is bad.
But admin not allowed attachment file with extension BIN
PostPosted: March 2nd, 2022, 7:31
KangKung wrote:
Hi MasterT,
Rename as DOC or similar extension
PostPosted: April 26th, 2022, 1:33
Thanks for support anyway, my problem solved, the correct firmware donor head saved hdd life.
